new actuator that reduces lag?
ill sell ya a actuator that reduces lag
, unplug the pipe off the actuator and uya will reduce lag
also ya reduce all forms of boost control too
sorry mate actuators aint anything to do with lag ( ok boost creep dont help BUT do affec lag that much ya would notice much !!!!)
sorry mate he's misinformed, all the actuator does is open and close the wastegate.
there are methods of bost control that mak the actuators do clever things, but at the end of the day an actuator is just an actuator, nothing more
twin outlet is a boost controler actuator buy julian godfrey ( he really is a god too
wont actually reduce lag THAT much though, will reduce boost creep though !!!!, only on big boost cars though, 7psi aint gonna notice the reduced lag
again its abit like ( but its no where near as crude) removing the actuator pipe and leaving JUST the presure of the spring allowing the wastegate to open, it will open later BUT not that much later !!!
)wont actually reduce lag THAT much though, will reduce boost creep though !!!!, only on big boost cars though, 7psi aint gonna notice the reduced lag
what about anti-lag will that reduce lag
twin port actuators are nothing new, renault 5 turbos had them since the mid 80s, they do fuck all worthwhile.
only way an actuator can improve "lag" if you want to call it that is by holding it shut till full boost, and even a 30quid dawes device will do that for you
the 30 quid dawes device works very very good steve i shit you not
, there not goot a big boost aplications but are ok upto 30psi
down side is they seem to make the boost come in with a bang
, thats not good in thw wet and rwd
, there very good systems though , very underated imo
worked really well on my car, there was a noticable diferance from the standard actuator.
Better looking aswell
Ima had one aswell and he was impressed as far as i know, and thats saying something
thats because benn the actuator ya had on before wasnt a -34 i bet but a worn out -31
. if thats the case then YES ya would notice it
, to eliminate boost creep is what they do ( as i know you already know, just telling others
, to eliminate boost creep is what they do ( as i know you already know, just telling others 20K+ Super Poster.
ginge, benn had the "boost controller" fitted at the same time, and thats what made his less laggy.
it works a bit like what switch has got, but its a bit more complicated as it uses a twin port actuator
