Convert Sierra to 5 stud hubs??
Old Mar 29, 2010 | 04:51 PM
Gav Diamond's Avatar
Gav Diamond
Default Convert Sierra to 5 stud hubs??
Hi guys
Does anyone know if it is possible to make a 3dr Cosworth 5 stud instead of 4 stud.
Just an idea at the minute but would like to know if its possible and what parts would be required.
Have seen it on a Escort Cosworth but didn't look into that more as may be different parts due to 4wd
Thank you
Old Mar 29, 2010 | 05:17 PM
Harris.'s Avatar
Harris.
Ive been told to use grananda cosworth hubs to go over to 5 stud . theres a few on ebay
Old Mar 30, 2010 | 04:10 AM
Gav Diamond
Thanks mate, will look into that
Old Mar 30, 2010 | 07:00 AM
Yes easily possible, as above or have your 4 stud hubs redrilled to 5 stud, easy as that.
Old Mar 30, 2010 | 10:07 AM
LINCOLN's Avatar
LINCOLN
Gav - not so easy to redrill 5 stud on 4 x 108 (unless you do 5 x 108 - welding the material makes them hard as glass). Either way you orientate it one stud id going to foul.
Granada hubs run and smaller front wheel bearing so you will have to run there upright (not too good for roll centre).
pm VIC off here as he has done this - he had some custom made
Old Mar 30, 2010 | 10:14 AM
PAUL S's Avatar
PAUL S
The rear hubs also have two big access holes drilled out of them for the hub carrier bolts, which also throw a spanner in the works for re drilling.
Best option is grannie hubs on the rear and sleeve the bearing carrier down on a set of 3dr fronts so that the granada hubs will fit.
I went another way and had new hub faces made, but thats not cost effective really, and those have now been sold.
jessie_rs
62
Aug 6, 2019 09:27 PM
Sierrasideways
Oct 8, 2015 06:37 PM
yorkie92
Sep 6, 2015 05:34 PM
jc1989rs
Sep 5, 2015 08:09 PM
hopper350
Sep 4, 2015 12:53 AM
