mk3 for circuit
Old Mar 28, 2010 | 06:56 PM
fordailles's Avatar
fordailles
Default mk3 for circuit
good morning.
here is one mk3 for circuit constructed with one very tight budget.
debut du montage moteur
modif du colecteur d'admission en 4 paps
Old Mar 29, 2010 | 05:36 PM
paprst's Avatar
paprst
Nice little beast you got there!
You know how to treat a mk3 , your previous escort rst built was fantastic.
Tell us more about the spec of it.
What kind of bike bodies you used?
Keep up the good work!
Good luck
Old Mar 29, 2010 | 05:54 PM
gazm's Avatar
gazm
thts one very clean shell my friend.. nice one
Old Mar 29, 2010 | 06:06 PM
mk3_escort's Avatar
mk3_escort
Advanced 5 Door User
Blimey if that was pulled from the undergrowth in England there'd be no floor left.
Top job so far
Old Mar 29, 2010 | 06:40 PM
wess-rs's Avatar
wess-rs
Very nice mate! good luck with the rebuild!
Old Apr 22, 2010 | 06:43 PM
z-inside's Avatar
z-inside
A Ford never die
Good luck
Hi, i'm the trainee of fordailles and builder of this car.
The first RST is always too fantastic, 850kgs and 200bhp...and a very race body.
This new project use 1000 GSXR bike bodies modify and assembly with a fiesta XR2I EFI inlet manifold. Kent cams FZ2002 (open 12mm instead 9 and 288° )
there are many many hours of modification on this car, we started 2 years ago, so we will try to put in somes other pics.
Thanks for your nice message
Old Apr 22, 2010 | 07:20 PM
Top work mate.
Old Apr 23, 2010 | 08:11 AM
z-inside's Avatar
z-inside
A Ford never die
rear brakes = front fiesta disk brakes + rear scorpio brake shoe
front brakes = Mondeo disk Ø290mm and RSTURBO S2 brake shoe
rear wheel axle unit = + 8cm fully adjusting and all uniball rotuling
front wheel axle unit = monobloc and adjustable + 8 cm , axle RSturbo S2 , tierod from RSI and pivot from escort MK5
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
liamT74
Sep 23, 2015 10:24 PM
