New oil pump - use old cover?
Old Mar 28, 2010 | 11:31 AM
AndyPen's Avatar
AndyPen
Default New oil pump - use old cover?
I've got a new 2wd pump from Goode but it didn't have a baseplete or the circular pipe guide a the top where it goes into the block. Assume I just use the old ones???
Baseplate is a little scored - not much but was wondering whether to have it refaced first??
Old Mar 28, 2010 | 11:57 AM
COLEYST200's Avatar
COLEYST200
did you get a pinto pump then i go one for my 3dr and used the old lid i did face it up as i have a lathe but if you have a good oil stone it should be ok
Old Mar 28, 2010 | 12:21 PM
I would face the cover, might as well while it's apart, depending on how deep the marks are could be done on a piece of greenhouse glass with valve lapping paste, but wouldn't cost much on mill, would only take a few mins.
jonfoc
16
Sep 11, 2018 05:35 PM
Chopshop85
Sep 12, 2015 06:42 PM
rog
Sep 4, 2015 07:24 AM
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
