fuel/running problem
Old Mar 27, 2010 | 03:20 PM
madmatt74's Avatar
madmatt74
Question fuel/running problem
Hi guys can anyone help i bought my escort xr3 in jan and the guy who sold me it said i have to put lead replacment in when i refuel which i do . Do i need to do this as my stepdad has a mk4 escort and doesnt need to . The car isnt running very well i am wondering if its the replacement lead i put in , matt . ps the car is an 1982 model
Old Mar 27, 2010 | 08:47 PM
It depends a lot on how you drive, the cvh engine having a alloy head will have steel inserts in it anyway, often these are adequate if using normally, but if ragging it I would get the head off and make sure/get coneverted to decent lead free seats, not expensive.
As yours is a carb model, it will have the 32DFT carb, good little carb it is.
What running probs are you having, they did have a bit of an appetite for the accelerator pump diaphragms, but that apart very good units.
Nearly forgot PICCIES please!!
Old Mar 28, 2010 | 11:08 AM
martysmartie's Avatar
martysmartie
Running on unleaded won't cause running problems, although a slight retard on the ignition timing may be needed, but can damage engine (Burn valve seats out as there not hardened) but as said depends on how cars driven and conditions, I.E towing, lots of motorway driving or just hard driving if just normal driving should be fine.
Martin
Old Mar 28, 2010 | 01:16 PM
madmatt74's Avatar
madmatt74
Hi tabetha the car runs rough on idle seams to use a lot of fuel i only get 140 miles on a full tank (£30) which isnt much before i had it the carb was reconditioned . Looking back at the last 20 mot's the car has only done 20k so stood a lot . What pics did you want regards matt .
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
