Radio codes...?
Old Mar 26, 2010 | 10:07 PM
Thrush's Avatar
Thrush
Irritating c........
Default Radio codes...?
How can I find out the code for my Connect van's radio? Not got the handbook and the sticker doesn't appear to be anywhere in the van (usually either in the glovebox or on the sun visor) and at some point I need to disconnect it to fit an cable for the AUX input!
Do I need to ring Ford and quote a serial number or something? Or os there an "easier" way?
Old Mar 26, 2010 | 10:56 PM
Ginge !'s Avatar
Ginge !
just finding my feet
you need the serial number mate, it starts with a M and if your local dealers dont sort it PM me the number and ill sort it for you
Old Mar 26, 2010 | 11:01 PM
Thrush's Avatar
Thrush
Thanks pal
Old Mar 28, 2010 | 08:03 PM
Thrush's Avatar
Thrush
Got the serial number off it today, but it starts with a V not an M. V then 6 numbers. Looked all over the net, but can't find any code progs etc that will work with the V serials. Fortunately, I managed to get the Aux Audio connector plugged in without unplugging the main power/wiring harness, so turned out I didn't need the code anyway!
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Flatlinedan
Sep 18, 2015 12:41 PM
fuzzy
Sep 4, 2015 10:11 PM
