Fuel pressure regulators??? 2.9 XR4X4
Old Mar 25, 2010 | 09:48 PM
Scottie_'s Avatar
Scottie_
Default Fuel pressure regulators??? 2.9 XR4X4
Hi folks,
Can anyone tell me what the difference is between the 2 different regs fitted to these cars. I have an 1989 and a 1992 but they have different regs. One has the 2 hose tails opposite each other and the other has them at a 90 Deg angle.
Is it only the hose tail angles that are different?
I did ask the guy at ford but
Old Mar 26, 2010 | 06:11 PM
Don't know for sure but suspect they are the same pressure which is what counts, try to look up the pressure for both years instead ?
Old Mar 26, 2010 | 07:13 PM
Scottie_'s Avatar
Scottie_
Yea they both run 3 Bar so recon it should be fine, I was told they are different to suit either the alloy or steel rail, As long as it gets a good seal i cant think of a reason it shouldn`t work fine?
Old Mar 27, 2010 | 07:54 AM
So long as it seals it will be fine.
JK12
33
Apr 26, 2021 12:09 PM
timsrs
Nov 13, 2018 11:48 AM
steve.rst
Mar 15, 2016 08:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
