injection problem
Old Mar 25, 2010 | 07:32 PM
Conor Harrington's Avatar
Conor Harrington
Default injection problem
i have a question could a blowin exhaust from the front of the play havoc with the injection system by it running lumpy by having to muh oxygen into the mix
my megane has come up with check injection and it started when the exhaust started to blow and when you put the gas on it seems to suck in excess air
any help would be good
cheers
and before u all say i know its no ford sorry
Old Mar 25, 2010 | 08:32 PM
Conor Harrington
bump
Old Mar 25, 2010 | 08:35 PM
botters's Avatar
botters
competant bodger
yes mate if its blowing in front of the lambda sensor then it will effect the fuelling of the engine
Old Mar 25, 2010 | 08:38 PM
Conor Harrington
right excellent so a simple weld coudl fix the problem?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
jonnyenglish
Sep 21, 2015 07:31 AM
