map sensor question
Old Mar 24, 2010 | 10:14 PM
stu21t's Avatar
stu21t
Default map sensor question
on a map sensor there are 3 mounting lugs,
1 of these lugs has a metal contact that goes inside the sensor, obviously an earth.
how important is it?
mine has broken off and will not solder back together, no matter what i try i cant get a good connection.
is it now knackered? do i need to get a new one? or will its still be ok?
Old Mar 24, 2010 | 10:20 PM
ECU Monitor Enthusiast
It will be fine
The earth isnt to power the map sensor, its purely for shielding.
As long as the sensor is mounted at least 12 inches away from the coil and leads, you will be fine
Old Mar 24, 2010 | 10:36 PM
stu21t's Avatar
stu21t
Yea it's about 12" above a wasted spark coilpack. And the wiring for the map sensor is shielded.
So cool hopefully nothing to worry about.
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
tib2220
Sep 14, 2015 12:33 PM
