car window
Old Mar 21, 2010 | 11:35 AM
ADT168's Avatar
ADT168
Default car window
hi everyone.
my car window is slow going up, sometimes it stops and you have to wait a few seconds, then it goes up, its ok going down.
any suggestions what it could be,
is there anything i could put in the window rubber to make it go up easier?
any info appreciated regards
ashley
Old Mar 21, 2010 | 12:54 PM
Thrush's Avatar
Thrush
Irritating c........
What car for a start?
Generally, it'll be down to either the motor getting tired, or the mech being out of line (ie, needing adjustment). In most cases, dousing the front and rear channels in the door frame with plenty of WD40 will usually help a lot. Stripping the door down and coating the runner and ends of the mech arms with LM grease won't hurt either.
You need to see if there's any/much play in the window - grab the window when it;s half way up/down and see if there's much in the way of front to back movement in it that might suggest the mech needs adjustment. Compare it to the opposite glass to see what difference there is
Old Mar 21, 2010 | 02:31 PM
ADT168's Avatar
ADT168
hi thanks for the info,
its a vw polo 1.4 y reg.
the window itself has no play back and forth or up and down.
ill try wd40 in the rubbers.
Old Mar 21, 2010 | 06:08 PM
Thrush's Avatar
Thrush
No play suggests mech isn't particulary worn allowing it to pitch and dive in the frame getting stuck. So it's probably just a tired motor, and WD40 should help you out a bit I think. Use the can with the straw in the nozzle, and liberally spray the front and back felts in the frame, right down into the door and up to the top. Don't be afraid to get loads in there - more the better.
JoeyBoyden
Jan 4, 2024 02:36 PM
liam-rst
Aug 10, 2015 08:46 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
