escos doesnt like rain?
Old Mar 20, 2010 | 04:36 PM
m4ttyrs's Avatar
m4ttyrs
Default escos doesnt like rain?
Now i dont usually use the cossie if its raining but sometimes you just get caught out dont you? yesterday when i was out it started raining while i was on the motorway and the car started missing on full boost then when the rain stopped after a while the car was back to normal. anyone any ideas?
Old Mar 20, 2010 | 05:13 PM
3dormatt's Avatar
3dormatt
Mine is doing something very similar! Went out today in the rain and it's missfiring like a twat; not on boost though, it's fine once the turbo is spinning!
Have you still got the 2 multi-plugs on the near side inner wing? I think they may have something to do with it??????????
Old Mar 20, 2010 | 06:05 PM
martysmartie's Avatar
martysmartie
What he ^^ said, or could possibly if heavy rain going through louvers onto ignition system?
Martin
Old Mar 20, 2010 | 07:01 PM
ECOS95's Avatar
ECOS95
Check if the car has the tray under the engine. My friends BT did the same & we think it was due to rain getting into the engine bay & affecting the Dizzy. His was missing the tray.
Old Mar 28, 2010 | 07:07 PM
Kelv's Avatar
Kelv
Almost there!
first point of call would be to check the wiring deterioration within the 2 big multiplugs on the passenger side inner wing.
you wont go far wrong in having them cut out and bypassed.
Old Mar 29, 2010 | 05:53 PM
Dave Hewy's Avatar
Dave Hewy
Mine has a boost problem when on full boost but only in 5th gear (90mph+) I adjusted the crank sensor as there was about a 5mm gap and it's slightly better. Thinking about it now it has only started since i removed the undertray to change the oils. Maybe its a coincidence or maybe the undertray keeps the wind from effecting sensors????
Old Mar 29, 2010 | 06:36 PM
ECOS95's Avatar
ECOS95
Could be worth refitting the tray to see if it fixes the problem, cheap fix if it does.
My ST is fine no matter what the weather & doesn't run with a tray as some monkey at a garage didn't refit.
Old Mar 29, 2010 | 06:42 PM
ECOS95's Avatar
ECOS95
Thinking about it the vents on the bonnet are designed to pull hot air out of the engine bay at speed & vent hot air when parked up after a run.
With no tray on & the car on the move it would pull the air from under the car, which when its raining is very very damp
gcfcos
59
Oct 6, 2015 05:04 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
Vacuman
Sep 22, 2015 12:09 PM
Bailes1992
Sep 19, 2015 02:17 PM
Mickeystewart
Sep 9, 2015 04:04 PM
