spark plugs question
my cossy stage 3 runnig rich. my plugs are black dry so its runnig rich and every 4 weeks i have to change plug iam using champion 59 plugs and it will hold back if i dont change plug every 4 weeks could i turn down the co with out altering the set up off the engine
thanks people
thanks people
PassionFords Creator
thanks people
thanks people
my car runs good so that would mean the conections on the map sensor is ok or am i wrong and stu ive changed all sensors and had the car set up and it was perfect and then i changed my head gasket and this starts running rich
RichardPON, my car does have a problem cos it uses alot of fuel Ł20 gives me if iam lucky 80 miles and plugs are dry and black would that make my car smoke
Then I'd say you need to get your car set up.
On a very similar spec, I wouldn't use too much fuel at all on greens, and changed the plugs every 2000 miles because I wanted to, and not because I had to.
chowfornow
14
Jan 5, 2019 09:01 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
