cometic headgasket
Old Mar 19, 2010 | 05:28 PM
bad boy rs's Avatar
bad boy rs
Default cometic headgasket
Just bought one of these for my saph, anyone fitted one ? any tips ? its the group a metal one, ive herd its a good idea to use some sealer
cheers paul
Old Mar 19, 2010 | 05:40 PM
fatmike's Avatar
fatmike
Metal headgaskets are very good IF you have two flat surfaces. It requires your head and block to be very true as there is little room for play. With a fiber gasket, you get a little room for error. I was recommended by tabetha on here to run a yb 0611 group a gasket. I run 400+ and it has coped no problem at all. This is what I would recommend.
Papillon's Avatar
Papillon
i had one, used a recommended sprayglue, didnt seal, leaked from the oil channels. had a skimmed block, head wasn´t but measured straight. changed to o-rings and grp a gasket instead. might have sealed if i had retightened the bolts some people say.
Old Mar 19, 2010 | 05:46 PM
bad boy rs's Avatar
bad boy rs
mmmm ok not what i wanted to hear, block is straight and head has been skimmed, im wondering if i should get the fibre one now
Old Mar 19, 2010 | 06:07 PM
Papillon's Avatar
Papillon
i would, unless you want to risk taking it apart again? i know from experience it aint that much fun but maybe thats just my opinion.
Old Mar 19, 2010 | 06:12 PM
Cossie_ray's Avatar
Cossie_ray
I heard the same thing about about multi layer and group A metal ones. The two surfaces must be completly flat. I went for the YB 0611 Group A Victor Reinz HG as this is much more forgiving if the two surfaces are not completly flat. Many people run the YB 0611 with 450+ BHP with no problems.
Old Mar 19, 2010 | 06:32 PM
grcossie's Avatar
grcossie
I had same problem whit 3layer wrc gasket, change to grpA yb0611 and find after that
Old Mar 19, 2010 | 06:37 PM
bad boy rs's Avatar
bad boy rs
has anyone fitted one and its atchualy worked ?
Old Mar 19, 2010 | 06:50 PM
JoeRS22's Avatar
JoeRS22
looks like you need to change it mr p......
MARCOSWORTH's Avatar
MARCOSWORTH
Yes mate, fitted mine in combination with ARP stud & nut kit after i rebuild the engine, have done about 15k miles with no problems and used no sealer or whatsoever
Old Mar 19, 2010 | 06:57 PM
bad boy rs's Avatar
bad boy rs
any tips mate ? was it on the recomended torque settings
Old Mar 19, 2010 | 07:06 PM
MARCOSWORTH
This is what i've done
Torque in sequence up to 60 lb ft, then 80,100, then finalise at 120lb ft.
If you're using the ARP stud & nut kit tap out the holes to clean up the threads and use a little bit of engine oil on them when torquing
Old Mar 19, 2010 | 07:14 PM
bad boy rs's Avatar
bad boy rs
cheers mate, how come no sealer ?, was that torquing in one go or did you leave for a few hours and check
Old Mar 19, 2010 | 07:27 PM
MARCOSWORTH
Copied from Cometic website;
Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a .001" thick viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
I did this in one way if I remember correctly
Old Mar 19, 2010 | 07:52 PM
bad boy rs's Avatar
bad boy rs
cheers for that mate just read up about it on the website, dry it is then, wish me luck
Old Mar 19, 2010 | 08:00 PM
MARCOSWORTH
Fingers crossed for ya
JoeyBoyden
20
Aug 22, 2015 03:23 PM
redracer
Sep 12, 2004 10:09 PM
simonc
Jul 24, 2004 04:46 PM
simonc
11
Jun 30, 2004 11:16 PM
