bypass valve leaking?
Old Mar 19, 2010 | 07:05 AM
pacwest's Avatar
pacwest
Puller of the Wrench
Default bypass valve leaking?
I have my stock bosch valve going to atmosphere right now until I get a decent hose to the turbo and at idle it's open a bit. Well it seems a lot. Capping it with my hand or thumb makes the idle drop quite a bit.
Normal?
Old Mar 19, 2010 | 10:37 AM
grcossie's Avatar
grcossie
Thats normal on all dump valves, exept dual pistons valves, which you have to use on cars whit air flow meter
Old Mar 19, 2010 | 02:41 PM
pacwest's Avatar
pacwest
Thanks, this is my first speed density turbo car, the vacuum seemed normal etc.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fudgey
21
Sep 30, 2015 06:19 PM
