Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
SA MK5 cortina
Old Mar 18, 2010 | 11:35 AM
lrw's Avatar
lrw
Default SA MK5 cortina
Hello all
Greetings from a fellow ford-nut......I'm from cape town ...South africa
I drive this.....(not quite older tha 1980....its a 1982)
XR6 interceptor (came standard from factory as a 3.0 V6 with triple 42 webers on it...and some other bits and pieces)
only it now has this in it.......
Its also now a 3.8 (using the later 3.4 crank/rods/pistons....and upped the bore/stroke on that) 2 t3/4 turbos (T04E 57 trim compressors with .63 A/R turbines)...bit laggy ...but make sure its in a straight line when it winds up
Amongst other things are MSD ignition....1000cc injectors, 3 fuel pumps (1 lift to surge tank...2 main supply)...etc etc
Its currently been off the road for about 6 months...busy installing some 340mm discs and 8pot calipers
Old Mar 18, 2010 | 04:56 PM
cossytonyt's Avatar
cossytonyt
very nice mate bet thats a handful
Old Mar 18, 2010 | 05:27 PM
GrimV8's Avatar
GrimV8
Smokin'
Like it
Old Mar 28, 2010 | 02:50 AM
bortaf's Avatar
bortaf
Fooking beautiful mate
Any more pics
Old Mar 28, 2010 | 03:36 AM
Darylc.'s Avatar
Darylc.
49cc superbike!
Old Mar 29, 2010 | 02:09 PM
lrw's Avatar
lrw
Any more pics
not many....owing to it looking like this now (theres a 1mm layer of dust on it)...been on blocks for the last 6 months (still start it up now and then)
mainly because i'[m busy fitting these....(the discs are in the mess above somewhere....i've also changed the rears to discs/sliding calipers)
the brakes REALLY are long overdue......car is insanely fast in a straight line...but doesnt stop so well....must just get the rotor hats made up then its ready for fitting
Old Mar 29, 2010 | 02:15 PM
Less.'s Avatar
Less.
having a mid life crisis
like that reminds me of my old MK5 Cortina my second car when I was 16,you going to restore it?
Old Mar 29, 2010 | 02:30 PM
lrw's Avatar
lrw
nah....too much fun as it is now (took me about 3 years to get it to where it is now).....
although...the way i built it ....to get it back to stock , all i have to do is take the turbo motor out, replace with original motor (with its triple webers)...take off intercooler and other bits)....and its good to go
I didnt want to cut holes into bonnet/front valence panel (for turbo and intercooler) for that specific reason....so just hung the intercooler under front bumper......that way...undo a few bolts, change engine...and its nearly original again
Old May 27, 2010 | 09:11 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
How much power has that got
I had a cossie turbo engine in mine, about 280bhp and that was mental
Steve
Old May 27, 2010 | 10:20 AM
lrw's Avatar
lrw
Steve
a shade under 500 i'm trying for closer to 600 when it starts up again (new 1200cc injectors.....2 new fuel pumps....and a couple other engine bits)....o and i have a NOS system too....but that hasnt been plumbed in yet.....so if i dont get 600 on the mods alone......i'll add the gas (i'm going to add the gas anyway )
since the body is basically pretty crap....engine has torn sections of the welding already (all the twisting and stuffs)....but its plenty fun
it also seems to have this habit of breaking things lately, which is most annoying since it does that just when you really get going (o, and it uses WAY too much fuel in the process)
Old May 27, 2010 | 10:27 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mad
Sounds like you need to do a lot of seem welding to keep it in one piece
Good luck with it
Sod the fuel, who cares when your having that much fun lol
Steve
Old May 29, 2010 | 05:22 PM
I like the look of that.Have you got any more pics.
rex647
Mar 6, 2022 06:20 AM
massivewangers
30
Oct 1, 2015 07:40 PM
20/20 vision
Sep 29, 2015 11:27 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
