Xenon Problem
Old Mar 17, 2010 | 09:08 PM
Richie03Focus's Avatar
Richie03Focus
Default Xenon Problem
Hey Guys this is my first post on here and i know its probably come up lots of times before but i need help.
I bought OEM Xenon headlights for my 2003 Mk2 Focus and when i installed them all the lights worked except the xenon part. I know the person i bought them from and they were working fine before i got them.
Can anybody help ??
Richie
Old Mar 18, 2010 | 10:47 PM
RichieST's Avatar
RichieST
Did you change the wiring loom plugs and fit the auto levelling system? Pretty sure you need to do this to get them to work properly.
Might also have blown a fuse as they draw a massive current when they start up. Don't know if the fuse for xenon lights is bigger than the one for standard lights though...
Old Mar 18, 2010 | 10:56 PM
botters's Avatar
botters
competant bodger
be carefull working on the xenons mate its rare for it to happen but people have been killed by the voltage given off by the ballast unit on the lights!!
Old Mar 18, 2010 | 11:31 PM
Richie03Focus
Hey guys thx for the replies
i havent fitted the auto levelling system on this and the wiring loom i have fits ok. however im not sure if the standard wiring loom is maybe missing anything that is needed for the xenon part to work
The fuse hasnt blown as i have fitted my old lights back in for now and they are working ok.
I know the xenons have a mighty kick but im not wanting to mess about with the ballasts at all lol
any more ideas?
Old Mar 19, 2010 | 01:02 PM
RichieST's Avatar
RichieST
any more ideas?
I know someone did it when i was on a focus forum a few years back, and he definately had to change the wiring multiplugs on the car's loom to make them work.
Old Mar 26, 2010 | 09:39 PM
Lami's Avatar
Lami
Can anybody help ??
Richie
You mean the mk1.5 not the mk2 (2003)
What car where they on when working???? Were they std fitment, as the loom
connections are different for the xenons.
You need to bridge pin 6 and 8 as the xenon bulb has its own earth supply, the
mk1.5 only used 1 earth for the lights, where the xenons use 2
They will work perfectly without the auto levelling, you can wire them up so that
the manual levelling control in the car will work tho, although this is a little more
involved.
I do all my wiring inside the light unit, as then it leaves the cars loom std so if
you want to stick in the std lights at any time you can
Ive done around 15 pairs now
Old Mar 28, 2010 | 04:40 PM
Richie03Focus
Hi Lami
Yeah the other car had these as standard... and yeah MK 1.5 hehe. How do you wire it up for the manual levelling to work? What do you do for bridging this out as i would like to leave the car loom just incase i decide to change it back. I have the Headlamps off the car just now so i can do anything thats needed before fitting them to the car.
Richie
I can post pics if needed as well lol
Old Mar 29, 2010 | 08:43 AM
mozzy's Avatar
mozzy
Ford for life
I am sure i read somewhere that xenons need to be auto leveling for MOT purposes or is that rubbish
Old Feb 23, 2022 | 02:03 PM
Steve, nottingham's Avatar
Steve, nottingham
Default Xenon wire alterations to plug.
involved.
Hi Lami.
Could you please let me know which other pins need moving/ splicing in order to get the manual levelling to work?
many thanks in advance.
steve.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
