Mk1 Focus RS engine
Old Mar 15, 2010 | 09:22 PM
moondustka's Avatar
moondustka
Boooost!
Default Mk1 Focus RS engine
Just got a couple of questions on it, as they'll determine some things I'll have to account for.
1. Is the turbo water cooled?
2. Does it have a stand alone oil cooler?
Also, what boost can that standard turbo run, without any problems. Surely it can do a bit more than a bar?
Thanks,
Ben
Old Mar 15, 2010 | 09:23 PM
moondustka's Avatar
moondustka
Boooost!
Upon searching I've got the answer to No. 2 .. and now my last question
Old Mar 20, 2010 | 03:40 PM
Calvz-RS's Avatar
Calvz-RS
Calvz
Turbo is water cooled.. standard turbo's are good for 22psi some run 26psi and have had no issues
Old Mar 23, 2010 | 07:50 PM
moondustka's Avatar
moondustka
Boooost!
Ok that's cool. Thanks for the reply.
I'll be running it on omex and I'm aiming for 250bhp with everything standard. might require slightly higher boost for that though.
Old Mar 26, 2010 | 09:43 PM
Lami's Avatar
Lami
You dont need omex to see 250 mate
The FRS uses a water filled oil cooler (engine cooling system), its where the oil filter is.
Old Mar 27, 2010 | 10:58 PM
moondustka's Avatar
moondustka
Boooost!
Thanks for the info.. Now Me and brother have 1 of the 2 engines we need on a palette, I've had a ganders and can see everything, answered a lot of questions I had.
I've got omex as I was using it for a Fiesta Turbo lump.. Now changed to this, no point going back to standard FRS management when I can use omex So should make the 250 easily!
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
