Kitchen Under Cupboard Lighting opinions
Old Mar 15, 2010 | 11:43 AM
daviddunlop83's Avatar
daviddunlop83
Default Kitchen Under Cupboard Lighting opinions
I think im going to put lights under the cupboard in the kitchen and im going to be getting the wall tiled tommorrow so i need to ru nthe cables tonight for them anyway
Opionions wanted on which of the 2 types of lights would you recommend
Strip ones:-
Triangle type ones:- Either LED or halogen type?
Old Mar 15, 2010 | 11:50 AM
I would just lay some speaker cable in there flat figure of 8 type so you can use LED strip.
These are a LOT cheaper, I did this in me mum/dads kitchen, cost was Ł20 for 2 strips from deal extreme mostly white with a tiny hint of blue, looks ace on thiers as they have blue flint tiles, worksurfaces, can run these from ians with a resistor and a diode, or easier just but a 220-12v adaptor and plug in, last forever(100,000+ hours).
Old Mar 15, 2010 | 11:51 AM
stucos71's Avatar
stucos71
You get a brighter, more uniform light with the flourescents.
I've got exact same lights as second pic. They do look better, but you dont really see them anyway and the light is no where near as good.
Hope this helps.
Old Mar 15, 2010 | 11:54 AM
Paddy's Avatar
Paddy
Legend
Depends what you want it for.
Task lighting, go for the fluorescent.
Accent lighting, go for LED strips as mentioned above or this stuff from IKEA that changes colour [I have it in my home cinema set-up]:
http://cgi.ebay.co.uk/Ikea-Dioder-Li...p/220549098909
Old Mar 15, 2010 | 12:04 PM
daviddunlop83
Its more for lighting when working in the kicthen as the spot lights in the ceiling cause dark spots under the cabinets esp if you are standing there.
Old Mar 15, 2010 | 12:11 PM
stucos71's Avatar
stucos71
Dont fit spots under the units if thats the case. They dont give enough spread of light for working IMO.
Old Mar 15, 2010 | 12:13 PM
Oranoco's Avatar
Oranoco
Flourecent gets my vote, the light is more uniformed than it is with spots as they are close to the surface so you get bright and dark spots
Old Mar 15, 2010 | 01:12 PM
daviddunlop83
I went for these ones as they are small and neat looking:-
http://www.lightinglocations.com/lig...-6w-275mm.html
Flatlinedan
Sep 18, 2015 12:41 PM
The Enigma
Sep 12, 2015 10:12 PM
fuzzy
Sep 4, 2015 10:11 PM
