Focus Engine swap
Old Mar 15, 2010 | 03:15 AM
Webster87's Avatar
Webster87
Default Focus Engine swap
Hi All, I'm new to this site just hoping to get a bit of advice. I have a Mk 1 2001 Ford Focus 1600 zetec, the engine has gone and I need to replace it. What i'm looking to find out is can a puma 1600 zetec engine be fitted? Is there anything I would need to check or ensure the new engine has before buying it.
Would the engine be a straight swap, Does the ECU have to go with the engine or could the original ECU be used.
Thanks in advance.
Ryan.
Old Mar 15, 2010 | 08:48 AM
cjwood555's Avatar
cjwood555
IIRC the mounts are different in a Focus vs. a Puma/Fiesta.
ECU depends - is your Focus engine a black-top 'SE' or a metal-cam covered 'S'? If you change between the two you will need the new engine's ECU and loom. This is because the SE uses a combined air temp and MAP sensor in the plenum near the throttle body; whereas the S uses a MAF. If you change ECU, you will also need to change the GEM or CSM (depending on what's in your focus - unfortunately 2001 was the year everything changed so there's no way of telling without looking!) and the immobiliser chips in your keys.
Chris
Old Mar 15, 2010 | 03:30 PM
Webster87's Avatar
Webster87
OK cheers for that. So guessing it would easier just doing a straight swap for another focus engine? It's a blacktop SE engine in my focus and the puma I was looking at. Would the same apply for the ECU etc if I was swapping from a focus of same spec?
Old Mar 15, 2010 | 06:25 PM
Gaz 88's Avatar
Gaz 88
might as well just put a st170 engine in you can buy the full kit off ebay for 1k
Old Mar 15, 2010 | 09:38 PM
cjwood555's Avatar
cjwood555
Only straightforward if you have a facelift foci - otherwise the whole loom needs changing out to accomodate the GEM that the ST170 ECU expects to see.
Webster - if it's a black top then it'll drop+plug straight in.
Chris
JoeyBoyden
Jan 4, 2024 02:36 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
vdubo7
Aug 2, 2015 08:17 PM
