Can MSD Launch Control be fitted to your existing chip?
Old Mar 14, 2010 | 12:31 PM
Sonic Boom's Avatar
Sonic Boom
Default Can MSD Launch Control be fitted to your existing chip?
Can the software be added to the chip i've already got as Martoon mapped it in January and i'm very happy with it but fancy Launch control for the up coming RWYB 1/4 Mile day at Stratford Raceway.
Cheers Rich
Old Mar 14, 2010 | 12:40 PM
KSA-Cossie's Avatar
KSA-Cossie
Only if it's an MSD chip m8.
Old Mar 14, 2010 | 12:48 PM
sygjim's Avatar
sygjim
I think that Stu can do that
if Stu can't do, you can contact RPLAB, they can do the job ....
Old Mar 14, 2010 | 04:06 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Learn to drive
Steve
Old Mar 14, 2010 | 04:11 PM
turblower's Avatar
turblower
good post as i was wondering this too.....u got any contact for rplab?
cheers
Old Mar 14, 2010 | 04:50 PM
sygjim's Avatar
sygjim
the website http://rp-lab.com/hp.shtml
Old Mar 14, 2010 | 05:05 PM
Sonic Boom's Avatar
Sonic Boom
Originally Posted by cossie4i
Learn to drive
Steve
If you can teach me how to create boost without moving then i'll knock launch control on the head
Rich
Old Mar 14, 2010 | 05:07 PM
Sonic Boom's Avatar
Sonic Boom
Do you just send them your chip?
Or do you need to buy there software?
Cheers Rich
Old Mar 14, 2010 | 05:13 PM
fiend's Avatar
fiend
Rich
Would you not need Anti Lag aswell for that?
Old Mar 14, 2010 | 05:18 PM
Sonic Boom's Avatar
Sonic Boom
Launch control creates boost at a stand still at a set rpm;
Taken from MSD's website:
"Simply flick a switch and your L8 launch control or P8 Launch Control is active, all you have to do now is bury the pedal to the carpet and you will see, and hear your turbocharger come onto boost and your rev limiter activate at around 3750 rpm. Lift the clutch, disengage launch control and your away, your normal rev limiter is resumed and you are off down the road at maximum speed!
The boost depends on the spec of the engine but will likely be between 10 and 35psi whilst active."
Rich
Old Mar 14, 2010 | 05:19 PM
sygjim's Avatar
sygjim
Cheers Rich
it's like changing the firmware of your mobile phone, the program is change and the data are same than before ....
I am sure that Stu can do that because i know who had wrote the program ...
but it will be expensive, you will pay for the transfer work from one chip to another and you will pay for the little board under the chip which will crypt it...
and after, your original tuner will not be able to change something on your chip ....
Old Mar 14, 2010 | 05:21 PM
Paul_RS's Avatar
Paul_RS
The LC is a form of antilag.
Old Mar 14, 2010 | 05:37 PM
fiend's Avatar
fiend
Rich
Ah I see, cheers for the info!
Kyle Langford
27
Aug 5, 2019 07:54 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
EoinXR3
Sep 7, 2015 05:44 AM
155lee
Aug 14, 2015 11:21 AM
