Zetec Turbo... How much boost? Please help
Old Mar 13, 2010 | 05:25 PM
mondeo2000's Avatar
mondeo2000
Default Zetec Turbo... How much boost? Please help
I have a Mk2 mondeo with a 2.0 zetec engine. It is currently getting a turbo conversion and want to know what the best amount of boost i should run (psi).
I will be running the mk1 Focus RS turbo, manifold ect, intercooler standalone mangement, loom, bigger injectors ect, however I am not lowering the compression yet as I was not going to run anymore than 10psi. I am still running the standard clutch and internals.
With this conversion what is the best PSI to run so that my clutch will not slip, i will still have traction and internal can cope.
Thanks guys
Old Mar 13, 2010 | 05:26 PM
rs-tuner's Avatar
rs-tuner
It may slip at that mate
Old Mar 13, 2010 | 05:29 PM
mondeo2000's Avatar
mondeo2000
Yeah thats what im worried about. The first thing I am doing is the clutch (but that will be when I have the money and will not be for a few months). Any recommendations on how much boost I should run to be safe?
Old Mar 13, 2010 | 05:38 PM
focusrrx87's Avatar
focusrrx87
6-8 psi over in the states u can buy turbo conversion kit's which includes turbo, manifold injectors intercooler ect al 2 be used on standard internals they all say 6-8psi boost. Also if u look at powerworks super charger kit for the zetec they run at 8psi on standard internals and u can get a bigger pulley and up the boost wen you've get forged internals. So 6-8 psi m8 play it safe.
Old Mar 13, 2010 | 05:40 PM
burnzy's Avatar
burnzy
burnzy
what sort of gains do you get with 6-8 psi will there be quite a noticeable increase in bhp?
and keeping all the internals and comp standard does that mean you'll have no lag?
edit: sorry to thread jack
Old Mar 13, 2010 | 05:42 PM
rs-tuner's Avatar
rs-tuner
Roughly 200-220 bhp
Old Mar 13, 2010 | 05:45 PM
rich123's Avatar
rich123
here u go chek that out http://baileyperformance.co.uk/
Old Mar 13, 2010 | 05:48 PM
focusrrx87's Avatar
focusrrx87
depends on the spec of the engine really and the mapping. But roughly 200-240bhp the later bein much better speced eg front mount cooler cams bigger tb custom plenum ect. But if Ur not paying out 4 forged pistons and rods i dare say it's a pretty basic spec?? So id say low 200's at 8psi
Old Mar 13, 2010 | 05:56 PM
mondeo2000's Avatar
mondeo2000
Thanks guys, I have been told that I will running about 200-210bhp on standard internals, intercooler and standlone mangement, stage1 cams and bigger injectors with about 8psi boost. Im a little worried if the clutch will cope but i will find out in a weeks time (its going on rolling road so will tell you the results)
My plans are to uprate clutch, lighten flywheel and better brakes, then I will move on to lower compression and run more boost, however then i will have to look at limited slip dif as my car will just spin as soon as turbo kicks in.
Thanks again for all your advice
Old Mar 13, 2010 | 05:57 PM
burnzy's Avatar
burnzy
burnzy
cheers for the info lads just wondered i always thought there was no use in low psi conversions but looks like quite a big bang for buck, personally i dont no if i'd risk using standard internals, but guess it all comes down to price.
Old Mar 13, 2010 | 06:12 PM
focusrrx87's Avatar
focusrrx87
mine is bein built now spent about 4.5k hoping for 300bhp at 1bar 350 at in the 20's psi. Although I'll only do that on the rollers. Lol iv got a stage 4 6 paddle clutch and ford racing lsd 2 help get the power down forged bottom end alc bearings it's 2.1 now also. Goin in on may the 1st cnt wait
Old Mar 13, 2010 | 06:18 PM
rich123's Avatar
rich123
that lads made 328bhp the only things he did is forged pistons,bigger injectots,m/s ecu with cosworth t38 turbo cheap as chips
Old Mar 13, 2010 | 06:27 PM
focusrrx87's Avatar
focusrrx87
at what boost??
Old Mar 13, 2010 | 06:34 PM
rich123's Avatar
rich123
22psi
Old Mar 13, 2010 | 06:35 PM
rich123's Avatar
rich123
its on the link i put on here
Old Mar 13, 2010 | 06:39 PM
focusrrx87's Avatar
focusrrx87
gd power that. I saw the link but on passionford mobile so couldn't be bothered 2 read it. Lmao
Old Mar 13, 2010 | 06:42 PM
rich123's Avatar
rich123
lol its the same chap who mapped mine did that escort got realy good results from that
Old Mar 13, 2010 | 09:04 PM
mondeo2000's Avatar
mondeo2000
Focusrrx87 I see that your in Kent, any good places that will help with my Mondeo when I get it back? Need a paddle clutch done soon, then will being lowering compression, LSD ect
Old Mar 13, 2010 | 09:10 PM
crazycage's Avatar
crazycage
on that turbo on 22psi thats shit.
Old Mar 13, 2010 | 09:12 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
realy how comes? real question btw
Old Mar 13, 2010 | 09:16 PM
focusrrx87's Avatar
focusrrx87
conaught competition engines in sittingbourne they deal a lot wiv ford engines.
Old Mar 13, 2010 | 09:17 PM
crazycage's Avatar
crazycage
because thats a lot of boost and a big turbo ,i would want a lot more power than that
Old Mar 13, 2010 | 09:21 PM
clarke5700's Avatar
clarke5700
i thort a t38 was just a t34.63? a mate of mine made 397hp on a t34.63 @30psi so terned down to 22psi i would expect 330ishhhh
Old Mar 13, 2010 | 09:22 PM
crazycage's Avatar
crazycage
no mate its not
Old Mar 13, 2010 | 09:24 PM
mondeo2000's Avatar
mondeo2000
Ok thank you, I am in Maidstone so Sittingbourne is not far from me at all. Thanks again mate
Old Mar 13, 2010 | 09:26 PM
focusrrx87's Avatar
focusrrx87
Im also in maidstone shepway.
Old Mar 13, 2010 | 09:28 PM
focusrrx87's Avatar
focusrrx87
crazycage wot did u make at 1bar?
clarke5700's Avatar
clarke5700
no mate its not
okkk can you put me right then??
Old Mar 13, 2010 | 09:31 PM
crazycage's Avatar
crazycage
bigger rear wheel.
Old Mar 13, 2010 | 09:32 PM
crazycage's Avatar
crazycage
over 300 but on a smaller turbo why ??
Old Mar 13, 2010 | 09:33 PM
clarke5700's Avatar
clarke5700
bigger rear wheel.
ahhhh right thanks sorry if ive upset ya
Old Mar 13, 2010 | 09:34 PM
crazycage's Avatar
crazycage
what makes you think you have upset me ??im cool.
Old Mar 13, 2010 | 09:35 PM
focusrrx87's Avatar
focusrrx87
Just wondering thats all as i building mine. Jesus dude u need a chill pill. Lmao
Old Mar 13, 2010 | 10:42 PM
clarke5700's Avatar
clarke5700
i donno ive never met you but you seem very blunt/pissed off in all your posts? or maby its just me lol
Old Mar 14, 2010 | 08:49 AM
crazycage's Avatar
crazycage
not pissed off mate, but i am blunt thats just how i am but it come across more so on the net .
Old Mar 14, 2010 | 08:53 AM
Rs Cosworth 1's Avatar
Rs Cosworth 1
RS for life
Imo.
If your doing that do it right
Fully forged bottom.
It's the way i think about it,Yeah it'll be ok for a while but trust me the lust for boost will grab ya.So why not strip the engine and fully re-build forged Do it right first time less expense
Old Mar 14, 2010 | 09:05 AM
GUZZLER's Avatar
GUZZLER
bigger rear wheel.
both the wheels are bigger, its named on the size of the front wheel, ie; a T3 & T34 normally use the same shaftwheel (shaft & rear wheel are one part for those who dont know) but the T34 has a bigger compressor wheel & housing. The T38 will differ dependent on who made it, some are bigger wheels in a T34 shell, the TT one uses its own compressor housing.
my silver escos pulled around 340bhp at 22psi, although it would hold the power for ages. 430-440bhp peaking 32psi
Old Mar 14, 2010 | 09:25 AM
RickyLee53's Avatar
RickyLee53
Psi doesn't mean anything. A big turbo on 4psi will outflow a small turbo on 14psi. So it depends on your turbo/spec and how its mapped.
Old Mar 14, 2010 | 09:41 AM
SiZT's Avatar
SiZT
I think it was more the fact that a T38 is a larger, more powerfull turbo than a GT28 and both would probably be using the same (standard bar springs) head
Oh and I'm sure someone has done over 400 on a standard bottom end
Old Mar 14, 2010 | 10:25 AM
crazycage's Avatar
crazycage
well was a bit hammerd last night lol, it's not shit 330hp is fast by all means but there are much smaller turbo's that would do that power at that boost and have a bigger power band (t34 or gt28) would be my choice buget depending.
my gt28 maxxed out my 480cc injectors last year around 350hp and that was on 20psi.
p-s i have just clicked the link its not a t38 it says a t34 but on a ported head!! my head was standard bar the springs so i would still think it should be doing more for the boost.
