spacer on a inlet manfold cosworth
Old Jan 9, 2005 | 10:37 PM
abdr500's Avatar
abdr500
Default spacer on a inlet manfold cosworth
were could i by a spacer thing that fits in betwen the inlet manfold on a cossy
Old Jan 9, 2005 | 10:39 PM
Is that a good idea on a standard inlet ?
As your increasing the plenum volume yet not reducing the restriction of the crap design of the plenum elbow.
Old Jan 9, 2005 | 10:46 PM
Ginge !'s Avatar
Ginge !
just finding my feet
wouldnt ya ned a remap though if ya done it ???
Old Jan 9, 2005 | 10:47 PM
abdr500's Avatar
abdr500
seen it loads of time and have heard good things about them its not form me as i have a 500 plenuim but alot of m8s ask me so would just like to were i can by them from cheers
Old Jan 9, 2005 | 10:49 PM
abdr500's Avatar
abdr500
i dont think your gona need a re map
Ginge !'s Avatar
Ginge !
well the inlet manifold volume has gone UP but the presure whould be different im sure
anyone care to confirm or deny
Old Jan 9, 2005 | 10:52 PM
abdr500's Avatar
abdr500
ok lets see
Old Jan 9, 2005 | 10:57 PM
No remap yet your changin the air taken into the engine....
mmmm
sounds like a load of old shite to me
Old Jan 9, 2005 | 11:00 PM
Stu @ M Developments's Avatar
PassionFords Creator
Anything whatsoever that affects airflow in a positive or negative way will be totally invisible to an antique speed density ECU.
Ginge !'s Avatar
Ginge !
mmmm
ok now im confused as im thinking theres more air volume in the inlet ???
or if not the map sensor will read lower ???
im not too sure but just my way of thinking
Old Jan 9, 2005 | 11:01 PM
RichardPON's Avatar
RichardPON
Ginge,
The pressure inside the balloon is the same, no matter what size the balloon is.....
Old Jan 9, 2005 | 11:03 PM
BUT it takes longer for the air to travel from the butterfly to the inlets.....
THEREFORE it aint the same
(pressure is tho, as pressure is pressure, as in it measures the pressure so thats the reading)
Ginge !'s Avatar
Ginge !
yeah stu that helps , try in english , im not a scientist
Old Jan 9, 2005 | 11:04 PM
Ginge !'s Avatar
Ginge !
Ginge,
thats the best explanation to use, pon you should be a teacher !!!!
thats a explanation for dummys and one that i understand too
Matt's Avatar
Matt
the time taken to fill the baloon takes longer if its bigger though
id "guess" increasing the plenum chamber volume will effect throttle response
thoughts?
Old Jan 9, 2005 | 11:05 PM
Ginge !'s Avatar
Ginge !
thoughts?
now where getting techy again
pon help me out
Old Jan 9, 2005 | 11:29 PM
RichardPON's Avatar
RichardPON
thoughts?
Who was talking about time?
You might be right, but I really can't see it making THAT much difference............. hence it seems a little pointless unless you sort the elbow like Dingle said.....
Old Jan 9, 2005 | 11:30 PM
Ginge !'s Avatar
Ginge !
if ya sort the elbow the what happens
Old Jan 9, 2005 | 11:32 PM
RichardPON's Avatar
RichardPON
I think it's supposed to be a restriction, but I've never tested it myself so I couldn't be certain.
N.B. If above statement is too honest for PassionFord, it can be withdrawn at anytime
Old Jan 9, 2005 | 11:34 PM
Matt's Avatar
Matt
mapping has quite a lot to do with time id say rich
Old Jan 9, 2005 | 11:35 PM
RANJ's Avatar
RANJ
rods spacer/mods worked well
Old Jan 9, 2005 | 11:37 PM
Ginge !'s Avatar
Ginge !
SO WOULD THE CAR NEED A REMAP OR NOT !!!!!
with or without the elbow changing !!!!!
i was learning now im well confused
Old Jan 9, 2005 | 11:45 PM
RichardPON's Avatar
RichardPON
But he's also sorted all the other restrictions too though?
Old Jan 9, 2005 | 11:47 PM
RANJ's Avatar
RANJ
yes rich
alot of works gone into that inlet
Old Jan 10, 2005 | 07:40 AM
GARETH T's Avatar
GARETH T
i think any gain,, is a gain,, no matter is there is more pressing matters somewhere else
Old Jan 10, 2005 | 09:11 AM
Karl's Avatar
Karl
Norris Motorsport
As Stu has commented, any speed density ecu cannot correct for a change in air flow for a given air pressure. This means that if you change your plenum on a cossie engine you WILL need a remap.
In laymans terms this is because the speed density system uses estimated air flow (Or V.E. to be precise) based on rpm and air density. If you increase the engine air flow (i.e. +% on V.E) for the same plenum pressure (e.g. by spacing the plenum away from the trumpets) then the engine will run leaner and hence need remapping.
In addition increasing plenum volume has a dramatic effect on transient fueling as the volume of air between the cylinder and throttle body has increased. On L1/6 this can be difficult to do anything about and can result in slight hesitation between gear changes, but L8/P8 and better can all be remapped to cope perfectly with increased plenum volumes.
Old Jan 10, 2005 | 09:16 AM
Ginge !'s Avatar
Ginge !
cheers karl
verdict is I WAS RIGHT !!!!!!
Old Jan 10, 2005 | 11:40 AM
Matt's Avatar
Matt
no the verdict is...... you asked "wouldnt ya ned a remap though if ya done it ???" and now you know why
Old Jan 10, 2005 | 11:54 AM
SPADGE's Avatar
SPADGE
To answer the original question - I have one 50 quid delivered
Old Jan 14, 2005 | 06:23 PM
abdr500's Avatar
abdr500
SPADGE, ok have you still got the spacer then and do you know were to by them from as i get asked so much for them and if i turn up with 1 then thers gona be a few others thant whant them 2
Old Jan 14, 2005 | 08:25 PM
CosRush's Avatar
CosRush
I have a mate who is running one, but its a Phenolic one...
This does a excellent job of insulating the head temp from the inlet, and he has a temp graph to prove it, before and after fitment.
Means after boost the heatsoak to the plenum from the head is massively reduced therefore the Act sensor stays almost normal instead of shooting up...
Got some pix if anyones interested.
Oct 9, 2015 07:38 PM
Danielbetty
Oct 3, 2015 06:01 PM
GTR_STU
Aug 28, 2015 01:02 PM
Cosnada
Aug 27, 2015 09:15 AM
Aug 14, 2015 07:29 AM
