T34 turbo.
Old Jan 9, 2005 | 08:19 PM
Leggetts 4x4 Cossie's Avatar
Leggetts 4x4 Cossie
Default T34 turbo.
Right,
I have a Escort Cossie large turbo,
There is a hole above where the waste gate pin is, just before it connects to the down pipe, it has thread ? whats it for ????????
Old Jan 9, 2005 | 08:20 PM
Alps Pacino's Avatar
Alps Pacino
lambda sensor i think i would like to know if anyone can supply something to go in it to block it off as mine is going on a 2wd saph cheers
Old Jan 9, 2005 | 08:23 PM
Alvyn's Avatar
Alvyn
if your stuck put a mk4 Escort wheel bolt in it and yes it's the hole for the lam/sensor
Old Jan 9, 2005 | 08:24 PM
Alps Pacino
that will look the conkers that will bodgemeister
Old Jan 9, 2005 | 08:25 PM
Alvyn's Avatar
Alvyn
yea but you cant see it really
Old Jan 9, 2005 | 08:26 PM
pugo's Avatar
pugo
just screw an old spark plug in it... with the guts removed!!!!
Pugo
Old Jan 9, 2005 | 08:27 PM
Alps Pacino
i might give it a go then or try and sorce a nice little bolt and washer for it
Old Jan 9, 2005 | 08:28 PM
Leggetts 4x4 Cossie
But does anyone know for sure what the hole is for ?
I dont think its oil or water as its exhaust side of the turbo ?
Old Jan 9, 2005 | 08:29 PM
Alps Pacino
LAMBDA SENSOR almost possitive cant really say as i cant see it
Old Jan 9, 2005 | 08:30 PM
Alvyn's Avatar
Alvyn
have another look @ my 1st post for the answer
Old Jan 9, 2005 | 08:36 PM
nthorpey's Avatar
nthorpey
M12x1.5 i think ??? for t34 lambda sensor
Old Jan 9, 2005 | 09:17 PM
Leggetts 4x4 Cossie
So are we agreed
Cosnada
Jan 7, 2016 05:30 PM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
