Pinto Turbo, Progress
Old Mar 10, 2010 | 09:21 PM
Dan1281's Avatar
Dan1281
Default Pinto Turbo, Progress
i've been planning on doing a pinto turbo for about 4 years now since i had my old capri, got a few bits together then but never finished it
now ive got a sierra and i've nearly got all the bits to do it
heres the car
i made my manifold today
its not pretty but bloody strong
my intercooler, just fits nice in front of the sierra rad with the ports coming out in the right place in the bay
my turbos and other bits, one turbo for mocking it all up and testing then i'll change it, theres also a fuel pressure regulator there off a renault 5 GTT, this is so the carb allways has fuel pressure higher than the boost
the boost will be getting blown down the top of my 38DGAS
i should be making the plenum for the top of the carb on friday so i'll keep the updates coming
thanks for looking
Old Mar 10, 2010 | 09:34 PM
mattman1234's Avatar
mattman1234
Thats a heavy duty turbo manifold.When you gonna start,will follow this one
Old Mar 10, 2010 | 09:44 PM
RAPID 3DR's Avatar
RAPID 3DR
the flow not be very smooth through manifold,good look tho mate & hope it all works out.
Old Mar 10, 2010 | 10:03 PM
Morpheus453's Avatar
Morpheus453
looking forward to watching this progress. Hope it all goes well, and remember to take pictures of every single stage, guys like me love that sort of thing lol
Old Mar 10, 2010 | 10:29 PM
Dan1281's Avatar
Dan1281
well i'm going to make the carb top plenum on friday, find myself a bosch type out of tank fuel pump then hopefuly start assembling it early next week
Old Mar 10, 2010 | 11:03 PM
ShiftyOldScoob's Avatar
ShiftyOldScoob
this could be interesting!..good to see something a little different
Old Mar 10, 2010 | 11:06 PM
monkeyboi's Avatar
monkeyboi
keep an eye on this
Old Mar 10, 2010 | 11:12 PM
Readie Si's Avatar
Readie Si
i like this
Old Mar 10, 2010 | 11:39 PM
Joshy's Avatar
Joshy
Dreamer
love it!!!
Old Mar 10, 2010 | 11:51 PM
Tom_Cortina's Avatar
Tom_Cortina
looks a good one as people have sed keeping an eye on this one.
Old Mar 10, 2010 | 11:58 PM
Dan1281's Avatar
Dan1281
i've been telling myself i'm going to get it done for the last 6 months, i just got stuck in last week and bought a few parts
just need a fuel pump now, i might just go the scrap yard and get an injection tank
then its just odds and sods like pipes and jubilee clips but i've got some 2 inch pipe to make solid boost pipes out of, i might tidy the bay up a bit while i'm at it lol
check out my ghetto pcv valve
Old Mar 16, 2010 | 02:17 PM
Dan1281's Avatar
Dan1281
i made this yesterday
Old Mar 16, 2010 | 02:26 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
How you going to seal that to prevent boost leak?
Old Mar 16, 2010 | 02:38 PM
Dan1281's Avatar
Dan1281
i'm going to find some decent rubber to make a gasket and the bolts have rubber washers on them
also silicone
Old Mar 16, 2010 | 06:13 PM
Morpheus453
looking good.
A bit off topic but the big case full of spanners and wrenches looks like a good tool set, what make is it? Quite fancy one like that with everythink all in one box.
Old Mar 16, 2010 | 06:22 PM
Dan1281's Avatar
Dan1281
its a crescent set, Ł75 from cosco
its got loads in it, great for keeping in the car
this is the same set
http://cgi.ebay.co.uk/Crescent-211pc...item3ca9911c98
Old Mar 16, 2010 | 08:18 PM
Morpheus453
looks awesome for Ł75. Are the tools pretty goood quality? (sorry to take you off topic lol)
Old Mar 16, 2010 | 09:20 PM
Dan1281's Avatar
Dan1281
yeah they are very good, lifetime garentee aswell if i remember right
only thing i have against it is that there is a set of deep sockets but no deep 10mm
Old Mar 17, 2010 | 07:22 PM
Dan1281's Avatar
Dan1281
its on and working, didnt have time to put the intercooler on as i need to use the car, and i havnt put the proper fuel pump and regulator on yet so it backs off on boost but still, a good start
Old Mar 17, 2010 | 07:55 PM
Morpheus453
excellent, not a lot left to do then
Old Mar 17, 2010 | 08:35 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
awesome. How much of a difference over stock?
Old Mar 17, 2010 | 09:16 PM
mattman1234
that was quick
Old Mar 17, 2010 | 09:17 PM
mattman1234
looking good though,eager to see what it goes like
Old Mar 17, 2010 | 09:19 PM
H7 CYA's Avatar
H7 CYA
God only checked this the other day your not hanging about are ya!!
Old Mar 17, 2010 | 09:30 PM
R4N SS's Avatar
R4N SS
nice - now what it like
Old Mar 17, 2010 | 09:43 PM
Austin101's Avatar
Austin101
Your talkin sh** now
Is that a stock engine that your putting the turbo on.Did you do anything to the bottom end like con rods/pistons.Looking good keep it up
Old Mar 17, 2010 | 11:06 PM
Dan1281's Avatar
Dan1281
its just a standerd 202 block thansit engine i got from the scrap yard for Ł80, i've re-built the top end and the bottom end was in suprisingly good nick so i just left it, i've got a lot on tomorrow so i'm going to crack on a bit more on friday
need to fit a boost guage to
Old Mar 17, 2010 | 11:15 PM
Rsmat's Avatar
Rsmat
looking good mate. keep up the good work.
Old Mar 18, 2010 | 01:47 AM
Crazyass's Avatar
Crazyass
230km/h+ in an oil burner
this may sound stupid to most of you, but is that the standard carb, inlet manifold?
besides the obvious exhaust manifold, turbo, intercooler and plenum for the carb (great work by the way), what else do you need to do this kind of job?
cheers
Old Mar 18, 2010 | 02:00 AM
Dan1281's Avatar
Dan1281
cheers
the carb is just an old 38dgas of a capri, the inlet manifold is normal too, this is pretty experimental so far, i've not sorted the fuelling out yet, i need a high pressure pump so i can use the renault 5 turbo fuel pressure regulator, this alters the fuel pressure with the boost
i'm also planning on rigging a 5th (or 1st lol) injector in there somwhere, going to make it activate on a pressur switch
the ignition timing is going to need tweaking also
Old Mar 18, 2010 | 02:11 AM
alexno1dj's Avatar
alexno1dj
does the pressure of the turbo not affect the carb? Find this really interesting and what proper mechanical tuning is all about, not plugging into a computer. good stuff mate
Old Mar 18, 2010 | 02:16 AM
Crazyass's Avatar
Crazyass
isn't it best to use a turbo carb for this kind of projects?
external fuel pump?
also, is the inlet manifold from a capri?
Old Mar 18, 2010 | 02:46 AM
Dan1281's Avatar
Dan1281
external fuel pump?
it proberbly would be better, but i allready have this carb so i may aswell use it, i think the inlet is off a capri but not from a 3.0 like the carb
and yes, i'm going to use a bosch out of tank fuel pump as soon as i can get down the scrapyard and find one. like the old xr3i fuel pump
Old Mar 18, 2010 | 02:54 AM
Dan1281's Avatar
Dan1281
at the minute it does yes becuse the fuel pressure is too low and the boost pressure is stopping fuel from going into the carb. once this is sorted though it sould be fine
the float chamber is fed pressure through the breather as the box on top of the carb covers it. this means the carb SHOULD behave as normal because there is even pressure all through it
Old Mar 18, 2010 | 03:09 AM
alexno1dj's Avatar
alexno1dj
ah right i see, so its just a case of increasing the fuel pressure?
wont the vacuum effect be higher due to the turbo?
Old Mar 18, 2010 | 07:08 AM
Kverna's Avatar
Kverna
Virgin-popper
Think you will have problems feeding the engine with fuel when the pressure comes through the carb. These carbs is not built for pressure
EDIT: Just read the post above :P
Old Mar 18, 2010 | 01:06 PM
Dan1281's Avatar
Dan1281
you mean the vaccum that sucks the fuel in? i'm hoping it will be higher. there is more air going in so i'm hoping it'll suck plenty more fuel in too
Old Mar 18, 2010 | 05:56 PM
mhs's Avatar
mhs
nice work
Old Mar 18, 2010 | 07:01 PM
alexno1dj's Avatar
alexno1dj
yeah thats what I mean, should compensate and suck more fuel in
Old Apr 8, 2010 | 03:29 AM
ShiftyOldScoob
any progress mate?
