Escort MK6 Van, Zetec turbo on MS..
Old Mar 10, 2010 | 02:05 PM
xtrmjks's Avatar
xtrmjks
Default Escort MK6 Van, Zetec turbo on MS..
Here's my MK6 Escort van, originally 1.8D, bought this to use for work, soon got tired of diesel and this is result..
It's fully "home built" and wicked fun..
First was 2.0 ZT with GT30...
..using Skyline Nismo pump,
..new headlining, seats, carpet and some audio..
..then came custom Gaz coilovers and some wheels..
..Then had issue with oil pump and engine was Scrap!
Decided to build new 2.1 ZT with some more umphhh..
..and this is it now!
Curently running stg3 T4, external wastegate...and 18psi
and in everyday use!
Old Mar 10, 2010 | 02:09 PM
.Ross.'s Avatar
.Ross.
Nice one mate ... Glad you went Zetec Turbo and Not I4 ..
Whats it churning out?
Old Mar 10, 2010 | 02:12 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
ha ha love it mate!
Old Mar 10, 2010 | 02:13 PM
xtrmjks's Avatar
xtrmjks
Don't know..I've mapped my self, need to get it on rollers..
Old Mar 10, 2010 | 02:21 PM
pani_k's Avatar
pani_k
PassionFORD Member
WOW what a sleeper van! Bet that must upset plenty! How does it handle the power as it looks FWD to me.
Old Mar 10, 2010 | 02:32 PM
xtrmjks's Avatar
xtrmjks
it is FWD, I got ib5 box with modified ratios and LSD..
4th gear wheelspins at 100mph..
it's very violent!
Old Mar 10, 2010 | 06:03 PM
woolford's Avatar
woolford
thats top i like this. good work matey
Old Mar 10, 2010 | 06:08 PM
WongRS's Avatar
WongRS
wow! bet thats alot of fun! awesome.
Old Mar 10, 2010 | 06:09 PM
H7 CYA's Avatar
H7 CYA
Looks cool matey, bet you've shocked a fair few with that!!!
Old Mar 10, 2010 | 06:10 PM
maxmk5fiesta's Avatar
maxmk5fiesta
i love it mate. just wish it was mine.
Old Mar 10, 2010 | 06:13 PM
project rs's Avatar
project rs
was thinking of doing this to one of our work vans when diesel engine goes but turn it round and bolt a 2wd cossie box to it as easy to make tunnel in van as rear deck is high enough anyway and as the rear floor is flat should be easy to make mounting points up for box
Old Mar 10, 2010 | 06:37 PM
xtrmjks's Avatar
xtrmjks
That's what I was thinking next, but using volvo axle..or 4 wheel drive from mondeo..
Old Mar 12, 2010 | 04:00 PM
xtrmjks's Avatar
xtrmjks
Anyone here seen/heard of RWD or 4x4 conversion on mk6 van??
NEED GRIP!!
Old Mar 12, 2010 | 04:45 PM
jonny s2's Avatar
jonny s2
you done good there pal!
love it
Old May 12, 2010 | 04:36 PM
xtrmjks's Avatar
xtrmjks
update..
Old May 12, 2010 | 04:38 PM
xtrmjks's Avatar
xtrmjks
..Apexi AVCR, boost is now contrololled by gear..
FRS brembos..
more vans..
Old May 12, 2010 | 04:47 PM
wess-rs's Avatar
wess-rs
Very nicee!!
Do you have more engine pics mate..??
Old May 12, 2010 | 06:57 PM
3i_gaz's Avatar
3i_gaz
mega!! would look mega all one colour
Old May 12, 2010 | 10:38 PM
adie_mwell's Avatar
adie_mwell
like this alot mate wanna swap for my van
Old Sep 8, 2010 | 01:18 PM
xtrmjks's Avatar
xtrmjks
here's little update..
..GT30 on order, just waiting for that to turn up and then new down pipe and external wastegate set up to make..
van be going to paint in 2 weeks..nothing special, just respray in diamond white with black roof..
Old Sep 8, 2010 | 01:21 PM
xtrmjks's Avatar
xtrmjks
oh, and..
Old Sep 8, 2010 | 03:40 PM
Fantastic project
Old Sep 8, 2010 | 04:43 PM
MK4 CABI's Avatar
MK4 CABI
Old Oct 15, 2010 | 10:10 AM
KevDawg's Avatar
KevDawg
Mate, I love this car. Its something someone would see and say "Oh, its just a caddy!" - ha, how wrong you are.
May I ask if you have a 0-60? Also, doesn't torque steer snap your thumbs off?
4th gear wheel spin at 100mph - ha, that would scare me first time it happened
Old Oct 15, 2010 | 10:40 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Ace van mate! the ib5 holding up ok? what clutch you runnin
Old Oct 15, 2010 | 11:38 AM
Süni's Avatar
Süni
Van, with rollcage?
Old Oct 15, 2010 | 12:55 PM
xtrmjks's Avatar
xtrmjks
ib5 seems o.k..Alcon 6 paddle, no slipping
Tourque steer isn't too bad with grippier Yoko Parada rubber..you get use to it
some more pics,
rear discs,
new GT30 and new downpipe and wastegate set up,
Old Oct 15, 2010 | 01:05 PM
chaffe's Avatar
chaffe
Cool if it becomes a problem or restriction then the mk5/6 td and rs2ks came with mtx75, bigger flywheel too! straight swap
Old Oct 15, 2010 | 01:11 PM
xtrmjks's Avatar
xtrmjks
yeah, know that..then you need to add LSD..mtx ratios are better as well? and would it ude 2.0 zetec flywheel? can i run FRS box with zetec 2.0 flywheel or would i need FRS one?
Old Oct 15, 2010 | 04:09 PM
Zetecfiesta's Avatar
Zetecfiesta
very cool sleeper!
Old Oct 15, 2010 | 05:39 PM
G801WAC's Avatar
G801WAC
Doing It Better
hi very nice project and a sleeper too
good job on getting it running on meagsquirt ive tried it and had too may problems
Old Oct 15, 2010 | 07:08 PM
xrmalin's Avatar
xrmalin
I love this ive been keeping my eye out for you driveing around by my work
Old Oct 15, 2010 | 08:34 PM
Brian's Avatar
Brian
Excellent project
Brian
Old Oct 16, 2010 | 02:39 AM
AaronsKa's Avatar
AaronsKa
what injectors are you running? smart van!
Old Oct 16, 2010 | 10:51 AM
chaffe's Avatar
chaffe
yeah, 2.0 litre zetec fly, or FRS fly, and a FRS clutch all 240 mm, frs box has quaife atb, or you can buy an atb from the states for around 400 quid and fit it very easily yourself.
xtrmjks's Avatar
xtrmjks
What problems did You have?
Loving the estate, I go past it every day!
550cc Toyota Celica GT4
Old Oct 16, 2010 | 10:53 AM
chaffe's Avatar
chaffe
MS is easy if you follow the instrutions and have it wired up correctly
Old Oct 16, 2010 | 11:54 AM
G801WAC's Avatar
G801WAC
Doing It Better
hi it was the crank trigger you have to set the resistor pot in the ecu and with not having an oscilloscope to help it was a pain and never mind trying too set the gap for the sensor on the custom 36-1 trigger wheel
Old Oct 16, 2010 | 12:28 PM
xtrmjks's Avatar
xtrmjks
2nd that!
never had similar problem. I just adjusted pot manually..I've done few MS set up's now, with OEM trigger wheels or 36-1 trigger wheels..never had proplems. I think MS is very under rated! I like the whole "diy" attitude..
Old Oct 16, 2010 | 01:14 PM
bassboy's Avatar
bassboy
Hi mate excellent project u have there! Quick question. is that an OBX exhaust manifold? Where did you get it from?
