lambda/HEGO sensor on MSD closed loop on late cossie 4x4
Old Mar 9, 2010 | 11:45 AM
GLSMAR's Avatar
GLSMAR
Default lambda/HEGO sensor on MSD closed loop on late cossie 4x4
Did some checking on the lambda sensor last weekend due to fuel economy going south.
Start test at idle and warmed up - I have 12.8 volts going to the lambda sensor. The signal is .82 volts and I seem to have .08 volts on the earth wire. CO was running at 6% at idle (way too rich)
Re-set the ecu screw as per instructions for closed loop. – signal falls to .03 and 0 and then rises to .68 and jumps around to .44 to .7 . and sometimes back to 0 again. CO drops and goes up and down between .5% and 1.0% Does this mean the sensor is still working?
Is 12.8Vs high enough to heat the sensor - What should I look at to get this voltage higher if required?
Thanks,
Old Mar 9, 2010 | 01:14 PM
oldford's Avatar
oldford
12.8 volts should be enough for a heater. It's the same (or a little less) as the battery voltage. You can't get it higher.
Signal should be switching from lean (< 0.4 volt) to rich ( > 0.6 volt). That is the way closed loop is designed.
Was the co set at a correct level before? And if so, what was this? Something else may be wrong - like coolant temperature sensor or map sensor (hose).
Old Mar 10, 2010 | 01:34 PM
GLSMAR's Avatar
GLSMAR
Was in email with Stu - seems like most of these voltage issues are caused by the ageing wire/loom. I must go and rewire the fuel pump and probably the fans too.
DixieTheKid
Jul 23, 2023 10:16 AM
jason_nike
Aug 18, 2019 10:53 AM
Anutternutter
24
Aug 31, 2015 01:24 PM
yawiejon
15
Aug 9, 2015 06:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
