st170 induction
Old Mar 8, 2010 | 02:02 PM
ceejay2626!'s Avatar
ceejay2626!
Default st170 induction
hi guys, wanting to put an induction kit on my st170.
not too fussed bowt performance increases but want the one with the best 'roar'.
which one too go for????
Old Mar 8, 2010 | 05:29 PM
RichieST's Avatar
RichieST
Take the resonator off the side of the airbox. Best roar, and totally free!
Old Mar 8, 2010 | 06:08 PM
ceejay2626!
already running it like that bud, but cheers.
was just wantin to get it a bit meatier sounding.
Old Mar 8, 2010 | 06:15 PM
RS Juto's Avatar
RS Juto
Im running a k & n and it sounds mint.... ford complain every time it goes in for a service thou they say it drags in hot air ??????
Old Mar 8, 2010 | 06:21 PM
jammerrs's Avatar
jammerrs
mesh filters generally sound meatier, but im not sure if the car will like a mesh one, k&n would be fine, the bigger the better
cossie1000 - read tabethas thread about heatsoak in his cossie, if i find it ill post it you up. different car i know but the same princaple
EDIT: i found it https://passionford.com/forum/ford-s...resting-2.html
tried just taking the pre filter part of the airbox off, sounds good with a quality panel filter in and alot cheaper
Old Mar 8, 2010 | 06:29 PM
RS Juto's Avatar
RS Juto
Cheers i will have a look now
Old Mar 8, 2010 | 07:00 PM
ceejay2626!
would that be the 57i or gen2 bud?
how do u mean the pre filter part,are u meaning the whole bottom half?
Old Mar 8, 2010 | 07:22 PM
melinamotor's Avatar
melinamotor
Farpylee
Just put a K&N typhoon on mine, sounds great and came with a heatshield too. I have also attached another cold air feed to it just to make sure.
Old Mar 8, 2010 | 07:36 PM
RichieST's Avatar
RichieST
Induction kits don't work very well on the focus, in most cases they can loose power as they are all mounted so close to the engine and sit straight in the path of hot air.
The only ones that work well are the ones that are mounted down behind the front bumper.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
Marv888
Sep 26, 2015 03:44 PM
