O/S Rears Door central locking problem?
Old Mar 7, 2010 | 09:28 AM
goonerboy's Avatar
goonerboy
Exclamation O/S Rears Door central locking problem?
Recently bought a 2001 Ford Focus GHIA and have discovered that the offside rear door does not lock on the central locking. Also I have discovered the rear window and speaker on the same door does not work.
This lead me to check the multi-block connector in the pillar near the base of the door, to find it had been disconnected! thus why there was no power to the door. As soon as i connected the multi-block connector together the window worked, the speaker worked yet the main fuse (Number 63) blew and the central locking did not work on all doors.
I replaced the fuse after disconnection the multi-block connector and the central locking works perfectly but then have a dead rear door. Somebody said it could be a fault with the central locking mechanism on the rear door, how could I find out?
Many thanks,
Gary
Old Mar 7, 2010 | 07:12 PM
neil andeRSon's Avatar
neil andeRSon
i'll be interested in an answer for this to. apart from mine's connected but it don't lock..
Old Mar 11, 2010 | 10:45 AM
rscabrio's Avatar
rscabrio
Sounds like the latch is knackerd
Old Mar 14, 2010 | 04:21 PM
SJM1985's Avatar
SJM1985
Now i have this central locking problem on my focus 1999 all the time, after alot of looking around i discovered a few quick fixes. First the way i read to check your door mechanism is to lock it from inside and lock the doors using your key (remember to do both sides with key i tend to find when mine goes faulty my passenger front and rear door wont lock from the drivers door or but will do from passengers side) if the door actually locks then the mechanical mechanism is fine and youve got an electrical fault probably one of the wires inside earthing out or been rewired wrong. you can obviously just swap the multi_block connector for your other side and see if it locks then (ive been told that the connector wear out not too sure about it thou) it may blow your fuse again but at least you know its the wiring inside your door.
But for the other member whos multi_connecter is connected but door not locking theres a quick fix if nothing is damaged. Just open any door and press the door sensor 5 or 6 times really fast until your indicators flash,. Then go round, open and close each door your indicators should flash once for each door including the boot and buttons on your key.
If any dont then the sensor on that door is broken and this is what is stopping that door locking.
After youve tried every door leave them shut for about 1 min and your central locking unit will reset itself (your indicators will stop flashing when you open your doors) your rear door should lock now. Ive have to do this everytime it rains coz my passenger doors go funny. water must be getting into one of the door electrics some were but cant find it.
HOPE this helps mate
155lee
14
Aug 22, 2015 12:15 PM
borboyous
Aug 22, 2015 11:17 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Red_bull
Aug 9, 2015 08:34 AM
