What is meant by an "Internally Gated" turbo ?
Old Mar 7, 2010 | 08:58 AM
JimmyBoy's Avatar
JimmyBoy
Default What is meant by an "Internally Gated" turbo ?
This may sound stupid, but ive heard the phrase before but dont know exactly what is meant by an "Internally Gated" turbo.
To my simple mind, the majority of turbo's would be internally gated (ie, the turbo's you would get off the shelf, GT28, GT30 etx...), your more custom turbo's may be externally gated, is this right or am I way off the mark ?
How can you tell by looking at a turbo if it is internally/externally gated? I presume if the actuator arm leads to the wastegate on the inside (by the compressor housing?), then it is "internally gated" ?
I presume this is intenally gated :
Old Mar 7, 2010 | 09:01 AM
JimmyBoy's Avatar
JimmyBoy
and also this
Old Mar 7, 2010 | 11:10 AM
Red16's Avatar
Red16
You're right with what you've said.
Old Mar 7, 2010 | 11:27 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
As per what you have said, with an external gate its a completely seperate item which isnt part of the turbine housing, its sat seperately on the manifold, like my one here:
Where its mounted to the manifold totally seperate to the turbo.
Old Mar 7, 2010 | 11:35 AM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Why have 2 types? Does one have any advantages over the other?
Old Mar 7, 2010 | 11:38 AM
Chip's Avatar
Chip
Internally gated is more comact, external is more flexible, depends what the design goals are as to which is better, most circumstances you could get away with either.
Old Mar 7, 2010 | 04:08 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
More precise boost control with external type. More expense as well.
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
