Changing gearbox oil on cossie 2wd, advise please.
Old Jan 9, 2005 | 11:42 AM
simonc's Avatar
simonc
Default Changing gearbox oil on cossie 2wd, advise please.
Is the plug to top up the gearbox oil the one just above the reverse light switch, if so its a torx bolt but i can't get a torx socket on it as theirs not enough room as its too close to the gearbox tunnel, is their a special tool required or something ? Cant get the drain bung undone either at the mo
Simon.
Old Jan 9, 2005 | 12:26 PM
TIFF's Avatar
TIFF
Chasing Radders
Use a 1/2" rachet but without any socket on it
It is just a square hole if that makes sense
Old Jan 9, 2005 | 12:37 PM
simonc's Avatar
simonc
Yes but that is just for the drain bung only isn't it, 1/4 inch square drive.
What about the bolt u remove to actually refill the oil, isn't it a torx one or am i looking at the wrong bolt just above the reverse light switch.
Simon.
Old Jan 9, 2005 | 12:48 PM
simonc's Avatar
simonc
Ok thanks Tiff, found the refill bolt above the drain , i was looking on the otherside of the box Thanks
Simon.
Old Jan 9, 2005 | 03:33 PM
simonc's Avatar
simonc
Checked on the GGR site & it said box holds 2.55 L of atf, i thought the box was low on oil, only 1.2L came out, managed to get 2L of new oil in before it started to overflow out of the filler bung, where's the other 1/2 litre ?
Simon.
Old Jan 10, 2005 | 12:44 PM
Blakeya's Avatar
Blakeya
Probably hanging up in the gearbox mate!!!
Old Jan 16, 2005 | 07:54 AM
Ginge !'s Avatar
Ginge !
just finding my feet
you will never get all the oil out pof a gear box or a engine
Chas
Sep 21, 2015 08:57 PM
ekjim
Aug 17, 2015 08:57 PM
RsS2daz
Aug 14, 2015 05:26 AM
ray barker
Aug 7, 2015 09:00 AM
Bosch
Aug 4, 2015 05:14 PM
