can someone work out a compression ratio for me?
Old Mar 4, 2010 | 06:09 AM
B13 JUS's Avatar
B13 JUS
Default can someone work out a compression ratio for me?
as above. here are the details i know for a cosworth yb
block has had 0.1mm skimmed from it
head bowl 45.8cc
piston bowel 28 cc
piston diameter 91.4
Compression Height - 39.2mm
headgasket will be a genuine wrc gasket. not sure of the measurements.
Old Mar 4, 2010 | 07:18 PM
B13 JUS's Avatar
B13 JUS
anyone?
Old Mar 4, 2010 | 07:23 PM
Flatovercrest's Avatar
Flatovercrest
Allyman
head bowl 45.8cc
piston bowel 28 cc
I will need to know the actual bore diameter and the gasket thickness to give you a proper answer.
Cheerz,
Alex.
Old Mar 4, 2010 | 07:43 PM
B13 JUS's Avatar
B13 JUS
not sure what the bore diameter is. they are je pistons. not sure on the piston to bore clearance is. do you know what it will be?
Old Mar 4, 2010 | 07:54 PM
B13 JUS's Avatar
B13 JUS
Old Mar 4, 2010 | 08:25 PM
AlexF's Avatar
AlexF
try this
http://www.afracing.com/CR.xls
You WILL need to change the bore and stroke etc
YODI
Aug 30, 2015 01:12 PM
155lee
Aug 14, 2015 11:21 AM
Zoggon
Aug 10, 2015 10:39 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
