Cosworth questions
Old Mar 3, 2010 | 01:04 PM
Billy_RS's Avatar
Billy_RS
Default Cosworth questions
Is the abs pump the same on all cosworths?
Will a saff 2wd steering column fit an escos?
ABS ECU, are they all the same?
Cheers Guys in advance
Old Mar 3, 2010 | 03:05 PM
grcossie's Avatar
grcossie
Abs unit, is different on Escort and Sierra, maybe the pump itself, is the same. Abs ecu is also different on Escort, they have a g-force sensor signal in, from sensor under driver seat. 2wd steering column will not fit escos, as they have different mounting point.
Old Mar 3, 2010 | 03:20 PM
Billy_RS's Avatar
Billy_RS
Ok thanks mate
Old Mar 3, 2010 | 03:24 PM
grcossie's Avatar
grcossie
No problem mate
Anutternutter
24
Aug 31, 2015 01:24 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Caddyshack
Aug 19, 2015 07:29 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
