Engine stutters when accelerating
Old Mar 2, 2010 | 11:14 AM
poolielad's Avatar
poolielad
Default Engine stutters when accelerating
Hi all...
I have a Ford Focus Zetec year 2000...
The problem I have is when I accelerate the engine seems to stuttter before acceleration, it does it whether engine is hot or cold....
I have cleaned the spark plugs... anyone know how to fi this problem??
Old Mar 2, 2010 | 12:33 PM
phil_focus's Avatar
phil_focus
could be the coil pack
Old Mar 2, 2010 | 05:31 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
What plugs you running?
Old Mar 2, 2010 | 06:28 PM
tarmac terriost's Avatar
tarmac terriost
zetec's tend to eat plugs and leads,also coil packs tend to go down from time to time
also check lambda sensor is working properly had this go down once made it stutter.
also get the tps checked (throttle postion sensor).
also should get the maf unit on the air box checked to see if running properly,there is a way to test this unit simpley remove the air box when running and blow into the maf should make the car run lumpy,if it does nothing its faulty get a new one not second hand
hope this little list helps to emlimate a few things good lucky m8
Old Mar 2, 2010 | 10:28 PM
poolielad's Avatar
poolielad
Dont know mate, just a standard set, if it was the plugs, wouldnt it splutter and run badly when it is idle as well???? Or am I totally wrong as usual
It`s just i have spent a few quid on it lately, so trying not to have to spend to much on it
Old Mar 2, 2010 | 11:05 PM
phil_focus's Avatar
phil_focus
did it stutter before you did any work on it?
what work have you done?
when were the plugs last changed and were they gapped correctly?
Old Mar 3, 2010 | 01:09 AM
poolielad's Avatar
poolielad
Stutter as been there a while,but getting gradually worse, plugs changed about 10 month ago......
The work I have had done is: the front part exhaust changed, rear anti roll bar changed, oil changed and front pads changed.........
Could it be fuel filter????
Old Mar 3, 2010 | 01:36 AM
phil_focus's Avatar
phil_focus
check those no leak from exhaust anywhere including around the lambda sensor.
also worth pulling out the plags to check gap and condition (colour will tell you how well each cylendar is burning fuel) also whether they look the same condition accross each cylendar.
would be worth getting the fault codes read to see if anything has been thrown up that might help diagnose the problem.
Old Mar 5, 2010 | 08:30 PM
alexst0ne's Avatar
alexst0ne
If you've got an induction kit, clean the MAF sensor
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
hopper350
Sep 4, 2015 12:53 AM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
