steel pipe to rubber hose solutions
Old Mar 1, 2010 | 10:06 PM
sir nose's Avatar
sir nose
Default steel pipe to rubber hose solutions
im trying to find a safe way of connecting rubber pipe from injection pump to kunifer/steel underbody pipe.im trying to find out if there is a fitting i can use with a flared end to the pipe.something like below alhough the top pic uses an olive.anybody know a good website where i can find such fittings.hope this makes sense.
Old Mar 1, 2010 | 10:28 PM
burnzy's Avatar
burnzy
burnzy
how about doing it just like a brake line by having a custom rubber pipe made to take the kunifer pipe nut, you can get your own flaring tool for next to nothing then just scew it up, the pipe shouldn't cost much at all my mate had to have one made for his clutch slave cylinder and i'm sure it didn't break a tenner
i'm sure flea bay have the brake line bolts that'll screw into the female end of the rubber pipe
Old Mar 1, 2010 | 10:34 PM
sir nose's Avatar
sir nose
yes i could have the hoses made,i would prefer not to but its an option,cheers.
Old Mar 1, 2010 | 10:50 PM
burnzy's Avatar
burnzy
burnzy
for what it'll cost mate the security for a new hose on an injection system it's prob's not worth the hassle of risking a hose blowing from a bodge, less connections will mean less risk of it leaking under pressure too.
Old Mar 2, 2010 | 07:28 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I had the original steel pipes running from rear to front of car on mine. I then made a join at the bulkhead to Aeroquip fittings for the engine bay. I did this by measuring the OD of the steel pipe, then going into a hydraulics place who supplied me with a compression fitting then went onto the steel pipe and left a female thread. I was then able to adapt this female thread to the dash fitting I wanted. You could do the same, but adapt to a hose tail with a thread on one side.
Old Mar 2, 2010 | 06:50 PM
sir nose's Avatar
sir nose
"bodge"
i was thinking something like the pic below,i found some bits at work and mocked it up they wont do as they dont quite match but its a compression fit to the kunifer pipe with a barbed stub for the hose.
i dont want to just clip rubber hose straight to kunifer pipe without a swaged end and i cant think of another way.
ill go to my local hydraulics shop in the morn see if they have what i need.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
