overboost
Old Jan 8, 2005 | 07:35 PM
tur80's Avatar
tur80
Default overboost
Lo ppl ,
I found my turbo isnt really kicking in until 4000 rpm, and it is also overboosting, could it be dodgy amal valve or actuator? , I was thinking of junking the amal and putting a bleed valve in its place?...
Also water has been coming out the top of the header tank under pressure, but it was overfull
any ideas at all
thx peeps
Old Jan 8, 2005 | 09:28 PM
MK5RST's Avatar
MK5RST
what cam ya got in, is it timed right?, have u changed sumthing since this has started hapening?
Old Jan 8, 2005 | 09:44 PM
tur80's Avatar
tur80
nope havent touched anything at all. perhaps she needs a RR? , car is standard, apart for dv
Old Jan 9, 2005 | 10:47 AM
K18NEO's Avatar
K18NEO
I wouldnt put a bleed valve on there if you have a problem, because thats just by-passing the problem, deffo get it RR, then whoever does that for you will get it set up, if its standard, might need a new actuator?
Old Jan 9, 2005 | 10:57 AM
james_birch's Avatar
james_birch
yeah take it to a tuner!! best advice there is! doesnt have to be rolling roaded you can set up a car without it!
Old Jan 9, 2005 | 11:06 AM
tur80's Avatar
tur80
cheers peeps
TIFF
Jan 1, 2006 10:15 AM
jonny gav
Ford Focus RS
Jun 8, 2005 11:27 AM
007
Nov 14, 2004 05:15 PM
TurboBlower
Oct 15, 2003 10:49 AM
