Problem with cossie agen.
hello people can anyone tell me why my car is over fuelling as it f??king smells so rich and black smoke coming out of the exhaust.and you cansmell fumes in the breather system.and the water looks yellow ruste colour with like a oil film could it be the fuel pressure regulator seized open as the car has not been run for 3 years as i have rebulid the car.
thanks chris.
thanks chris.
try changing your Coolant Temp Sensor (blue sensor located at rear of head inlet side by dipstick)
could be faulty and causing your issues !!
worth a go for the price of a new sensor
I would first check/replace the CTS (Coolant Temperature Sensor) these go out of range after a while and is the main factor used for fueling for the base level of fuel injected right from zero degrees to boiling, if this is giving a duff reading I.E colder than it is the ECU will fuel accordingly.
Martin
Martin
Thanasis
Sep 7, 2015 07:33 PM
