ST170 Tidy Up *UPDATED 09/04/10*
Hi Folks
I've been spending a bit of time tidying up my ST170, so I thought I would take some pics to show you my efforts.
The last time I posted on this forum was in 2006 when I had my RS Turbo. A new job however caused me to part with my RS and replace it with an ST170. Here is are some pictures of when I first got it:
With only 17K on the clock is was an ideal investment for a good daily driver. Naturally being a Ford enthusiast I kept it clean. Here I was using Autoglym 'Superglym' and Extra Gloss Protection:
4 years and 40,000 miles later despite best efforts to keep it looking new, it looked nothing like it did and in desprite need of some TLC
The first job was to fix the damaged front splitter which I stupidly caught on a grass verge about 18 months ago!
Job done and a new front number plate added too!
After 4 years of cleaning the wheels with an acid based cleaner they had lost all their shine and started to corrode.
A refurb was therefore in order so I put the car on stands and took the wheels to www.wheelworksuk.co.uk
Whilst on stands I thought I take the opportunity to give the arches a good clean
3 days later the wheels were done! I had them fully stripped and repainted and purchased a set of new centre caps from Ford.
Before putting the wheels on I thought I'd get some form of protection on them, so I used Autoglym's wheel sealant for the time being.
Last few touches were a new set of 'Aero style' windscreen wipers all round and a new rear number plate. The reversing light was full of water so I sorted that out. I've also got a set of tailored car mats on order but they are taking ages in being delivered.
So... the car's looking better already. The second part of my plan is of course of full detail as soon as the weather allows. I checked my shed in preparation and thought I didn't quite have enough cleaning stuff so I placed a little order with polished bliss so all is ready.
Looking forward to getting stuck into a good valet and will post the resulting pictures as soon as I can.....
Cheers for looking
Si
Cheers for looking
Si
The splitter was Ł40 from Ford. It was a nightmare to fit though, because the cold weather meant you couldn't manipulate it into place.
Thank you all for your comments. Hope to do the full valet ASAP but it's meant to be heavy rain down here all week...
hi mate do you ever go to the west sussex meet at patching nr arundel i used to live in worthing for 8 years a while back and was at most meets .My Daughter lives in Shoreham so i get down there a bit.
You might find you'll need to take the whole thing off and try clipping it back on in one go. I couldn't fit my new one any other way.
No I've never been over that way. Since I sold my RS Turbo I've not really been to any meets.
Finally been able to give the car a full valet.
I decided it was too much to do what I had planned in one day, so yesterday afternoon I made a start on getting the interior sorted.
I gathered the items I'd be using, including my new tailor made mats which eventually arrived.
I then emptied the car.
The leather interior was due a feed. It soaked the leather conditioner up like a sponge!
Before:
After:
Lastly to save time for today I cleaned and detailed the engine bay and alloys
I used a Autoglym Powermax 3 on the engine and then pressure washed it and dressed the plastics. For the wheels I just used soapy water and two bucket method.
*** Day Two ***
Unfortunately todays weather wasn't quite as good as yesterday's. With the wheels and engine bay already sorted I could start straight away with foaming the car and leaving it to soak for 5 minutes.
I jetted the foam off and then cleaned the car using the two bucket method and my new lambswool mit.
Next stage was my clay bar kit. Was the first time I'd used a clay bar. Here's what the two bars looked like at the end
Here's the two major areas of concern I wanted to sort out with a two stage mop
I used Autoglym 03B on a medium pad and 02B on a light pad
I then finished off with a coat of Blackfire Polish
Next time I clean it I'll be putting a good layer of wax on it. Wanted to do it today but the air was starting to get damp so had to leave it. Also the pictures would have been a lot better if the sun was out. Overall though I'm really happy with the result of my little project, the car feels new again!
Thanks for looking
Before:
After:
*** Day Two ***
Thanks for looking
That's fuckin lovely mate, i am trying to find time to get mine done.It needs a good clay and i invested in some Valentine's wax to try on it.
Thanks for you comments.
Blackfire polish is one I saw recommended on polished bliss. The quality was noticable straight away.
http://www.polishedbliss.co.uk/acata...-products.html
Looks lovely matey, like new
My ST170 is the same colour. After a correction i cleanse with Limeprime then a glaze of Poorboys blackhole, wax with Dodo juice Supernatural and then seal with Zaino Z8. That combination you will be very happy with. Been meaning to try blackfire, the finish looks spot on
Sounds good Sp3no. I'm interested in trying some nice wax's and sealants next.
The weather was nice today and I hadn't used the car since the valet so I did what I had orginally planned and put a nice layer of Auto Glym Extra Gloss Protection on it.
Hi
Looking at these pictures above you have too big of a work area.
You should be splitting a panel of that size into about 6 smaller sections.
The lower picture is showing that the polish has not been worked enough and has not broken down properly hence why you have the buffer trails.
A good start non the less mate but think it would help you to have a read through the guides on Polished Bliss website or on Detailing World so as to hone your skills
Good luck with it mate
Thanks for your advice. I wasn't too sure how long to spend working a particular area and thought I'd rather do too less than too much.
One problem I found was I kept getting small random patches of compound stick to the car and I'd have to remove them by hand. I also thought I got quite a lot of dust. Was I using too much product?
Next time I will invest in some new compound I think as I've had those Autoglym ones in my shed for years now.
If your pad is drying out then give it a quick spray with QD to lengthen the working time for the polish. As said above you need to work in smaller areas maybe 2ftx2ft at the most. Typically your looking to work an area of this size for at least 5 mins untill the polish breaks down and goes clear.
You will get some dust but it should not be excessive. Wipe down the panels with panel wipe before applying product after polishing.
I used Menzerner polish which is regarded as one of the best, PO85RD 3.02 & PO85 RD should see you through most defects.
Cheers Sp3no. I might give it another go in a few months. This was the first time I used my machine polisher in about 2 years so I'm a bit of a novice. I will try working smaller areas for longer then and get some new polish too.
Certainly does not look too novice matey, looks tip top
keep it up. No one is born an expert. Im far from it, only been doing details for 18months but learnt allot from the guys at Detailworld.
My ST170 is up on ramps at the moment and will be for the next month as i have dropped the rear and sub frame off for a rebuild and clean!! I got it bad lol
keep it up. No one is born an expert. Im far from it, only been doing details for 18months but learnt allot from the guys at Detailworld. My ST170 is up on ramps at the moment and will be for the next month as i have dropped the rear and sub frame off for a rebuild and clean!! I got it bad lol
My comments were not made to put you down, more to try to help as thats what we are all here for
With regards to the small bits of compound sticking, make sure the shake the bottle enough as like you say they have sat for some time.
Also try to use smaller amounts and if you are getting alot of dusting try spraying a little quick detailer on as this will allow you to work the polish for longer as well.
It is all down to practice and you will find the more you do you will get better and learn how different products work.
I have tried loads of the different polishes out there and there are some people rave about but i just cant work out how to get the best from them, alot is trial and error and what works for one person may not work for another so just keep at it mate.
No worries Gav, I appriciate the advice! I'm looking forward to having another go soon and will definately be doing a few things differently. I need to invest in some new polish as my Autoglym ones are very old. I want to try some better quality pads and purchase some quick detailing spray like you mentioned. Also I think instead of trying a two stage mop I will just go for a light cut put stay on the panels longer. I've got my eye on this at the mo.
http://www.polishedbliss.co.uk/acata...05-polish.html
What do you reckon?
What do you reckon?
Si
I have not used the Megs 205 myself yet...(I do plan on gettting some) so cannot comment from my point of view.
However everything i have read from others opinions on using it is that it is a very good polish.
Just placed another Polished Bliss order for Menzerna 203s and a Gloss It polishing pad. I also bought a detailing brush so I can clean the pad during the valet.
I plan to have another go at machine polishing my car early next week. I've been reading a few guides on the Polished Bliss site and www.detailingworld.co.uk so hopefully this time I'll achieve a better finish without any buffer trails!
Looks flawless mate! My goodies arrived yesterday and the Gloss it polishing pad I bought feels alot better than the cheaper Menz pads I used last time.
Will post up pics of my second attempt soon!
Got round to my second attempt today!
It's been 5 weeks since my first valet and it was quite clear I had left buffer trails in the paint. I haven't taken many pics as just wanted to concentrate on getting it right.
Armed with some new polished bliss goodies I set about correcting my mistakes!
Here is what the car looked like after a wash. I used a shampoo with no silicone so it would strip the old polish off the car.
After polishing
All finished!
I think it has a much better finish than before. You can see the clouds reflecting on the bonnet
Well happy with the result. It took me 6 hours in all. I used Menz 203s on my rotary machine. Then Blackfire polish by hand and sealed it with a bottle of Autoglym 'lifeshine' I had.
Want to get a decent wax and a nice tyre gel next, but i'm trying to use all my old autoglym stuff up first.
Hope you like!
After polishing
All finished!
Hope you like!
