1998 Escort van fuel problem
Old Feb 22, 2010 | 11:30 AM
lowa's Avatar
lowa
Default 1998 Escort van fuel problem
Hi All, I have a 1998 escort van 55 which has a fuel problem. While out driving the other day it started to splutter and would not go past 40mph, I hade to keep changing gears to keep going. Then on my return it stoped running, after 5 min or so I got it going 1 mile later stoped again, I could'nt restart as I run the battery flat.
I checked the fuel filter and it seems in good nic, very clean, seals look good. Altough when I took the filter of I seen some ice in the bottom of the filter, not alot of ice but still ice.
Anyone know whats happening here and is ice normal in the filter (i dont think so, but i have to ask to be sure)
Any help would be great
Thanks in advanced
Lowa
Old Feb 22, 2010 | 06:17 PM
From your description I assume it's a diesel ?
If so yes the water is normal, ther eis a drain screw underneath for draining the water off every 2-3 months, just undo let a little diesel run out taking the water with it, then tighten back up, this will cure your problem.
Old Feb 24, 2010 | 04:35 PM
lowa's Avatar
lowa
Default thanks
Thanks that sorted it.
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
Old ford
Jul 31, 2015 06:50 AM
