power steering
Old Feb 21, 2010 | 05:32 PM
whittyscossy's Avatar
whittyscossy
Default power steering
Hi all look at tidying up the engine bay and removing the old cooler ( runs in the wheel arch then comes back on it self!?) and put a 10row cooler or something in its place. But I keep getting told i cant do that as the pressure will be to high? I don't want to go on the rack just. just remove that pipe.
Surly if the pressure was to high the plastic bottle would pop or push the pipe clips off??
I have seen cars on here done so any help would be great.
Whitty
Old Feb 21, 2010 | 07:16 PM
jon@work's Avatar
jon@work
There isn't any pressure in the return line. Fitting a replacement cooler as you propose will be fine.
Old Feb 22, 2010 | 06:30 PM
As said will be fine, there's next to no prtessure in the return as it is not being restricted, it's free to return to the tank, the tank is also not under pressure, it just acts as a reservoir for the pump, which creates the pressure used on the live side of the rack.
If you can oil cooler would be better before the pump as it helps keep the pump cool as well then.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
