Fiesta rs wont start
Old Feb 20, 2010 | 03:48 PM
rsfiesta2002's Avatar
rsfiesta2002
Default Fiesta rs wont start
Does any1 know what the symptoms are of a broken ECU? and also what would cause the fuel pump to keep priming? and a tapping noise from the injectors?
Old Feb 20, 2010 | 04:41 PM
Broken ecu will usually result in lots of different symptoms dependant on what part is buggered, should prime only at certain times I think on the RS ?, priming too often is no problem though(won't stop it running), check for sparks, check for injector pulse, with either a noid light or a analogue metre, do not use a light bulb.
Old Feb 20, 2010 | 04:46 PM
martysmartie's Avatar
martysmartie
Fuel pump is signalled by CPS, "Tapping" you hear from injectors is the pulsing so this is the first thing I would be looking at. Does sound as if something more may be wrong with your ECU though.
Martin
Old Feb 20, 2010 | 05:04 PM
rsfiesta2002
Thanks 4 your help guys
Old Feb 20, 2010 | 05:13 PM
andy130's Avatar
andy130
check earths mate,
JoeyBoyden
Jan 4, 2024 02:36 PM
paceo
Feb 3, 2016 10:31 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
slammedorion
21
Aug 6, 2015 11:38 AM
