focus rs mk1 diff into st170
Old Feb 18, 2010 | 08:39 PM
siany1997's Avatar
siany1997
Default focus rs mk1 diff into st170
Hi, building an st170 to hill climb regs and wondered whether a mk1 rs quaife diff will fit in an st170. The rules state that all casings and the position must remain as standard but internals are free. Any info much appreciated.
Old Feb 18, 2010 | 08:44 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Won't fit.
Focus RS is an MTX75 based box, the ST170 uses a Getrag MT285.
You can buy Quaife ATBs to go into the ST170 box though.
Old Feb 18, 2010 | 08:54 PM
siany1997's Avatar
siany1997
Cheers. Better work out if the 700 quid is worth it or not !!!! It buys a lot of tyres and entry fees.
Old Jun 8, 2010 | 09:31 AM
siany1997's Avatar
siany1997
Hi again,
Just at the point of buying a quaife atb for the 170. How big/small a job is it for the fitting? Anyone have experience of the job?
Also, just bought seats and harnesses. The recommendation is that the shoulder straps should be fixed as close as poss to horizontal behind the seat. There's no cage fitted as yet, so is it possible to get a decent mount for the straps without the cage bar ?
Thanks
Simon
Old Aug 13, 2010 | 09:02 PM
siany1997's Avatar
siany1997
Quaife atb fitted and gave it some abuse at Harewood last weekend (eventually).
Completely different technique required - Turn in at usual speed, then floor it and hang on, oh and don't lift or you'll get shitloads of understeer.
More understeer in the wet/damp than an open diff as well.
Zero understeer mid corner to exit on full throttle.
Bought from QK performance for £622 delivered.
Quaife quoting around £650
Can't recommend a diff enough. The st170 was spinning the inside wheel on the exit of every corner, wasting what power there is and chewing the tyres up.
Useful on the road, but you have to commit to the throttle early in the corner to get the best out of it.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
