head gasket gone
hi guys the head gasket has gone on my escos. its a small turbo model it s got full/ss exhaust de-cat indution kit and larger intercooler on it. i saw this head gasket set on ebay. item number 230409148113. what do you guys think or what would you recomend.
thanks scott
thanks scott
Hi,I would double check with the supplier that it is really a Reinz Grp A gasket included in the set - the one in the picture definately isn't a Reinz gasket. The Reinz gasket is dark grey with a black sealant bead, the pictured gasket is a red sealant bead. Item number 310197372343 shows a genuine Reinz gasket - this isn't a recommendation for the seller, just has a clear picture on there.Regards,MAHLE UK
Mc5506
Oct 5, 2015 09:57 PM
