misfire through carb
Old Feb 16, 2010 | 08:51 PM
robspop's Avatar
robspop
Default misfire through carb
hi i got a cvh escort i put a new head on,plugs rotar arm,diszy cap all the timing done but when hot it misfires through the carb help rob
Old Feb 17, 2010 | 03:47 PM
You probably mean it spits through the carb, check the CO and the ignition timing, if really weak or advanced timing it can cause this.
Old Feb 17, 2010 | 07:07 PM
robspop's Avatar
robspop
thanks set the ignition timing with the light to the timing marks but it still does it when it gets to the right temp
Old Feb 18, 2010 | 03:03 PM
I wouldn't take much notice of the ignition timing marks, ok to get it running, but best way is to tweak either way a touch at a time till you get the best result, still need to check the co.
Old Feb 18, 2010 | 06:44 PM
robspop's Avatar
robspop
ok will do thanks
mk3ste
Oct 17, 2021 10:09 AM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
