s2 fuel pump question
Old Feb 16, 2010 | 04:16 PM
RSandy's Avatar
RSandy
Default s2 fuel pump question
ok, when i started buying up parts for my rebuild years ago, i bought what i was told was an uprated bosch fuel pump from jamsport to suit my S2
now when its finally come to using it, im noticing the model number doesnt seem to match any of those listed as uprated rs turbo pump, which i believe wud usually be a 941 or maybe even an 044
mine is a bosch 910, im not sure whether this is even standard spec equipment, or even suitable for an rs turbo
more fool me for believing the supplier and not checking out the small stamped model number when it arrived, but a sneaky move if i have been done here, as i gave them the benefit of the doubt after 1st trying to sell me a used pump as new, which i was assured was just a communication error
if anybody can shed any light on whether or not this pump is suitable for use, it would be great, cos right now im a tad pissed off to be honest, mostly at myself
Old Feb 16, 2010 | 04:40 PM
haz87's Avatar
haz87
910 is standard iirc
Old Feb 16, 2010 | 04:46 PM
RSandy's Avatar
RSandy
well if so, disregarding the mixed feelings i have of wanting to shove this down sum1s throat in northampton , will it be ok for use for my spec?
not a big spec by any means, just a new standard bottom end, piper 285t-2, turbo technics stage 2 t3, turbosystems ecu.... etc
if i can at least use this standard pump safely, it will save me having to feel like more of a mug n buy ANOTHER new pump
Old Feb 16, 2010 | 04:52 PM
haz87's Avatar
haz87
If its brand new (or as good as new) with fresh wiring so its actually seeing the proper voltage i'd say it would be absolutely fine for at least 200bhp (probably alot more but i can't say for sure)
Old Feb 16, 2010 | 06:14 PM
RSandy's Avatar
RSandy
yeah its brand spanking new in a sealed bosch box, 1st time iv opened it stupidly, otherwise would have noticed the different number
managed to do a google search n mike rainbirds site lists it as an updated version of a standard rs turbo item, 130litres per hour, 5bar, so im guessing that will be fine for my needs, not going for anythin over the 200bhp mark anyways
Old Feb 16, 2010 | 06:24 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
The Bosch 910 will be perfect for your needs mate. Its uprated.
cheeRS
Chris
Old Feb 16, 2010 | 06:35 PM
RSandy's Avatar
RSandy
cheers dude, i feel slightly happier, and less likely to throw it at somebody now
least it looks cleaner than my old identical standard item
Old Feb 17, 2010 | 08:58 PM
RSTurboSI's Avatar
RSTurboSI
i needed a new Fuel pump as i started to get Starting problems,
Ollie Fitted me a Bosch 910, as he said mine was no good being Std, so yeah here's a second comment, and from a tuner as he supplied and fitted the parts. Which he stated this is a uprated/Upgrade pump.
That's Norris Motor sport. who also fitted me a new Fuel pump wiring/two way relay system.
Old Feb 23, 2010 | 12:22 PM
RSandy's Avatar
RSandy
problem solved
mark at jamsport noticed the thread, got in touch, and has very kindly offered to replace the pump for the 1 i originally purchased, even though its a very long time down the line
big thanks to that man, very nice gesture
Old Feb 23, 2010 | 09:30 PM
RSTurboSI's Avatar
RSTurboSI
Originally Posted by RSandy
problem solved
now that is what you call fucking top service. Nice one andy! Well done Jamsport.
Old Feb 23, 2010 | 09:34 PM
Rob_DOHC's Avatar
Rob_DOHC
Hi there, i bought a fully forged jamsport rst engine a few years ago with that sexy inlet they do..... just taken it out the box and its a bloody standard engine!
So Mark, if your reading
Old Feb 24, 2010 | 02:03 PM
JAMSPORT's Avatar
JAMSPORT
Rob, sure ill just nip down to the post office and get the new one posted, ill put a 1st class stamp on it for you, should cover it!
Andy, new one was sent out today as PM said, should be with you tomorrow by 3pm let me know if there are any problems
regards
mark
Old Feb 24, 2010 | 02:59 PM
Rob_DOHC's Avatar
Rob_DOHC
Thanks very much mate! I'll quit work so i can sit by the front door and wait for the postman.
Rob,
Old Feb 25, 2010 | 12:00 PM
RSandy's Avatar
RSandy
new 2wd cossie 941 pump arrived today, so no longer an issue if a 910 pump will do the job, as i have a cossie 1 now lol
nice way for it all to end, thanks jamsport! bloody quick delivery too
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
