Fords bloody prices! oil pump needed
Just came back from ford
wanted
oil pump - £145
head gasket - £49
bolts - £55
water pump - £185
hand brake cable (rear half) - £50
cam belt tensioner - didn't even ask
thats a total of nearly £500 with out any shells etc! tossers
Head gasket gen ford on fleebay is £39 so sorted, i bought the bolts.
My real question is... any one know where i can get a good pattern oil pump from, as i don't really want to ruin my engine, but don't particularly want to spend the 145 ford want.
Rob,
wanted
oil pump - £145
head gasket - £49
bolts - £55
water pump - £185
Rob,
An AE oil pump will be fine. I also used Motor factor head bolts as they are identical to the ford and cost a tenner a set. Water pump I paid around £20 for a Quinten Hazel from factors which was identical again to the ford one I had. All these parts lasted 40k miles on old CVH which was totally reliable on a T34 at upto 2bar until i dropped a valve...
Rick
Rick
i don't think i've ever bought a new oil pump, only ever had them fail if the oil level was too low and surged.
i kept all as spares too, so i have some spare for some change.
Thanks Rick thats really good info.
And Cheers John, i may well PM you with an offer later on mate, had a chat with a few people, going to strip the current pump and give it a good inspection, as rick said so far its a proven unit.
Was just more shocked over the prices! a few years ago bit from for weren't this dear!?!?! or were they? i've always had sierras.
Rob,
Rob,
Go on 'fordparts uk' and request some prices for the items you are after.....i bought genuine ford oil pump and some other bits when i was building an engine last year, genuine ford stuff but cheaper than the main dealers could offer me
always hear horror stories about them.tim
Is that how much it is for a genuine ford water pump now! 1 year ago i bought mine from ford for 65 pounds. they did tell me that those water pumps had been discontinued however they were brringing them back and they are dearer at 65 pound. but a whole year on and here we are 185 pounds down the line. wow. I have used a pattern one once. never again it lasted all of around 1500 miles if that before it started whining its arse off.
big_Rad
Sep 15, 2017 09:36 AM
track.focus'd
Aug 12, 2015 05:53 PM
