fuel pressure regulator
Old Feb 15, 2010 | 08:59 AM
skrats's Avatar
skrats
Default fuel pressure regulator
hi all , i have just noticed that the top of my fuel reg (at the front of the fuel rail) has a hole in it and it looks like something should be screwed into it , i have running issues at the moment and cant for the life of me remember if anything was ever in the hole !!!! should ther be ,,,, its a 4x4 saph
Old Feb 15, 2010 | 10:53 AM
oldford's Avatar
oldford
When new there's a plug in it. Under the plug is a screw which can adjust the pressure.
Be careful! If you turn the screw too far, it will damage the regulator.
Standard fuel pressure is 3.5 bar with key on, engine off.
Old Feb 15, 2010 | 11:21 AM
skrats's Avatar
skrats
i aint toughing it , but it dont matter if the hole is open ?? i was just making sure nothing was missing ?
Old Feb 15, 2010 | 01:55 PM
oldford's Avatar
oldford
No, doesn't matter. What are the complaints?
Old Feb 15, 2010 | 04:23 PM
martysmartie's Avatar
martysmartie
As said there is an Allen screw to adjust the pressure when new there was an alloy fitment in there to stop people tampering with it, and for good reason as there isn't a need to adjust it unless you have aftermarket chip which rarely are written for different than standard fuel pressure (3.5 bar).
To have it removed is pretty common unless you are lucky enough to own a totally standard one that has not been played with and will not effect running at all.
Whats wrong?
Martin
Old Feb 15, 2010 | 05:55 PM
Toe Knee's Avatar
Toe Knee
as said, if theres a grub screw in the hole then ur fine if not then u have a problem!! when i say fine thou obviously just being there doesnt mean ur pressure is set right!!
Old Feb 15, 2010 | 07:03 PM
If you think it is a pressure problem, just measure it.
When the plug is removed, along with the hard plastic sealant below it, it can then be adjusted if needed.
When the plug is removed this introduces a the tiniest of air leaks as the top half of the reg is connected through the vac pipe to the inlet, but certainly not anything you even need to consider it's so insignificant.
There are two diaphragms inside seperating the top(vacuum) and bottom(fuel) half of the reg, if just one goes it will affect it.
Old Feb 15, 2010 | 07:14 PM
Toe Knee's Avatar
Toe Knee
also remove the intercooler hose and have a look if theirs an oily substance in the thrrottle body, on my last cossie it had it and obviously i thought it was oil but on good advice from Stu, it was actually a fucked regulator and was fuel not oil in the TB!!
Old Feb 16, 2010 | 01:10 PM
Simply sucking on the vac pipe will confirm this, or not as the case may be.
timsrs
Nov 13, 2018 11:48 AM
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
