mondeo door glass removal
Old Feb 13, 2010 | 12:53 PM
phil-c's Avatar
phil-c
Default mondeo door glass removal
Hi. I need to replace a broken drivers door window....local scrapyard has one but haynes manual says you have to lower glass before removing....
so is it possible to remove glass without lowering it, cos obviously the electrics won't be working on a scrap car. thanks for any help. (mk1 glx mondeo).
Old Feb 13, 2010 | 02:16 PM
Alzay's Avatar
Alzay
You will struggle, there are two central bolts that need to be removed to take the glass out, You might be able to force the scissor lifts down manually but it will be a struggle.
Old Feb 13, 2010 | 02:26 PM
The ball that carries the plastic wheel on the regulator can be popped apart from the plastic wheel.
Old Feb 13, 2010 | 02:59 PM
RS500/364's Avatar
RS500/364
drill the rivet on the mount holding the glass or bolts then pop off one roller then the other should do the job
Old Feb 14, 2010 | 08:22 PM
dangerousbrian's Avatar
dangerousbrian
depends what year mondeo..easiest way is to cut the cable and force the glass down..mk1 mondeos have two 8mm bolts to attach to the mech and later ones have 2 clamps using 10mm bolts.never seen a mondy with scissor style mech mind
Old Feb 17, 2010 | 08:55 AM
phil-c's Avatar
phil-c
Default thanks.....i got it out!
I had to cut through the upright ally channel & then through the cable (with a dremel). Took about 10 mins & 2 cutting discs. Couldn't have done it at a scrapyard though cos no elec supply & i don't have cordless dremel! Many thanks to those who replied.
Old Feb 17, 2010 | 09:15 AM
daviddunlop83's Avatar
daviddunlop83
If you where to remove the motot itself from the mechanish as its bolted onto it then would you not be able to push the window down as the motor wouldnt be holding it up anymore?
YODI
Aug 30, 2015 01:12 PM
Aug 29, 2015 08:16 PM
mrice0107
Aug 21, 2015 07:55 PM
borboyous
Aug 14, 2015 06:51 PM
no1trancefan
Aug 4, 2015 12:48 PM
