xr3i oil pump
Old Feb 12, 2010 | 03:39 PM
XRSTI's Avatar
XRSTI
Exclamation xr3i oil pump
how can i tell if my oil pump is ok?
engine seems to run very hot
new rad water pump engine fully rebuilt just didnt fit a new oil pump
bit silly i know
when engine running and oil filler cap off seems there a bit of pressure blowin out
is this normal
cheers
Old Feb 12, 2010 | 07:25 PM
With a new engines till the rings are bedded in there will be more blow by than normal as they won't be sealing as well as used engine.
If the oil pump was ok then there is no need to change it, did you inspect it ?
If the oil pump was causing excess temps due to not enough oil supply, the temps would be the least of your problems, you'd know by now for sure, maybe new engine paranoia!!
155lee
Oct 27, 2015 04:55 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
