Decat pipe
Old Feb 11, 2010 | 11:15 PM
Irish aRSe's Avatar
Irish aRSe
Default Decat pipe
Does anyone know can the scan gauge 2 be used to clear lambda sensor fault?
Reason i'm asking is i'm thinkin of getting a decat pipe and i hear sometimes you get this fault if a decat is fitted.
cheeRS
Old Feb 14, 2010 | 08:29 PM
das's Avatar
das
you do unless you got tuna
Old Feb 14, 2010 | 09:36 PM
2001ode's Avatar
2001ode
Better way is to fit a MIL Eliminator
http://www.teamtorquesteer.co.uk/cat...liminator.html
Other way : ask to your tuner if it is possible to modify his ECU soft for no action on MIL.
Regards.
Claude
Old Feb 16, 2010 | 01:55 AM
Irish aRSe's Avatar
Irish aRSe
Default MIL Eliminator
MIL Eliminator looks like the right way to go. Spot on, thanks for that.
Old Feb 19, 2010 | 12:15 PM
zammofocus's Avatar
zammofocus
i was just reading these post and ive fitted a exhaust to my car and an engine light has come on and its too do with the lamba sensor how do u sort that out
Old Feb 19, 2010 | 04:58 PM
Irish aRSe's Avatar
Irish aRSe
Did you just fit a CAT back exhaust or a De-cat pipe as well?You should not get the MIL indicator on the dash if its just a cat back exhaust. Normally only get it with a decat pipe, if this is the case then go for the MIL eliminator as stated above.
Old Feb 19, 2010 | 08:02 PM
RS16iDale's Avatar
RS16iDale
if have got a mil eliminator for sale if any1 is intrested
Cosnada
Jan 7, 2016 05:30 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
