2001 mondeo problems
Old Feb 11, 2010 | 07:59 PM
dearing5's Avatar
dearing5
Default 2001 mondeo problems
hi guys, im looking to buy this mondeo to make some cash on!! it has some problems though...
1. eml on
2. smokes heavy (blue) on hard throttle
3. idles lumpy (engine rocks) but clears when revved
4. slight knocking noise from somewhere
any ideas? he has thrown money at it in the past by dropping something in the engine so had to replace it! it was running mint until a few days of having it mot'd.
its a cracking motor but just dont want to waste my time and money if its really funked.
thanks
Old Feb 12, 2010 | 10:29 AM
dearing5's Avatar
dearing5
anyone?
Old Feb 12, 2010 | 10:49 AM
oldford's Avatar
oldford
Start by having the fault codes read, either by a dealer or an independent with the correct scanner equipment. Make sure you get the number of the fault codes.
Old Feb 12, 2010 | 12:27 PM
dearing5's Avatar
dearing5
is there any ideas what sensor it could be by the symptons? is it the headgasket due to the blue smoke?
i still haven't bought it yet lol
Old Feb 13, 2010 | 08:20 AM
dearing5's Avatar
dearing5
ttt
Old Feb 13, 2010 | 10:45 AM
martysmartie's Avatar
martysmartie
Have you checked the obvious, I.E is the ignition system healthy not causing the misfires. To check HG failure look at the oil fillter cap for mayonaise and also the header tank for an oily film indicating the two mixing together, misfire can also be caused by HG failure.
If blue smoke suspect engine wear.
Martin
Old Feb 13, 2010 | 01:41 PM
dearing5's Avatar
dearing5
yeah cheers, would the eml come on if the gasket has gone though?
Old Feb 13, 2010 | 04:52 PM
martysmartie
Indirectly yes, if car is misfiring and rocking engine which could be seen on the knock sensor hence illuminating the EML. You can easy reset the KAM by removing the 1A fuse (Purple) for a few seconds.
Martin
Old Feb 13, 2010 | 05:05 PM
dearing5's Avatar
dearing5
what the kam? and remove the fuse while the engine is running?
Old Feb 13, 2010 | 05:19 PM
RS500/364's Avatar
RS500/364
At the aution two months back not running 03 plate £350
what are you expecting to make IS IT WORTH THE CRAP IF YOU CANT TELL WHATS WRONG ALREADY !
Old Feb 13, 2010 | 05:32 PM
martysmartie
KAM "Keep Alive Memory" is what stores the fault codes etc when you remove the fuse it will clear this do not need ignition on at all to do it.
Martin
Old Feb 13, 2010 | 06:23 PM
dearing5's Avatar
dearing5
yeah i know mate but im hoping to make some money to fund my corsa lol, it is running and i can pick it up cheap! and only knowing vauxhalls i thought it would be best to ask...
just remove the fuse then without ignition or engine running...then if it comes straight back on is there a way to read the codes without a scanner?
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Brickhouse
Sep 20, 2015 11:47 AM
roomey
Sep 19, 2015 08:40 AM
Flateric_2002
Sep 15, 2015 08:41 AM
